CEDAR SHAKE SIDING
/ CEDAR SHAKE SIDING #1
Jimmy Joe
Gold Member
Medford Wisconsin
Built a porch/3 season room on to house my wife would like the porch exterior to be sided with cedar shingles for siding. The rest of the house is vinyl siding what do you think of the idea and how much maintenance do you think it will be?
/ CEDAR SHAKE SIDING #2
I put cedar shingles on my house and garage with disappointing results. Wrong location, wrong pitch, wrong installation.
But I did choose to use them again on this project.
Well Ventilated, on strapping, special nails hand installed (not air nailed) and they will see no traffic.
/ CEDAR SHAKE SIDING #3
My friend has a 4,500+ sq ft house with them,,,
He constantly battles carpenter bees,, :eek: then there was the year he had to stain the house,,, a truck load of 5 gallon buckets of stain,,, :confused2:
BRICK, thank you!! LOL! :thumbsup:
/ CEDAR SHAKE SIDING #4
Wife wants cedar shingles, give her cedar shingles. They have been used for a few centuries now and still seem to work. They like a little air behind them. Benjamin Obdyke makes a mesh.
They do require a sealer every so often. Sun and weather will drive that.....along with the quality of the product
/ CEDAR SHAKE SIDING #5
Every 5 years reseal goes easy with a cheap spray gun . Carpenter bees kept in check with raid has to be done in the spring after the thaw otherwise they get out of hand. But their is nothing like the character and warmth of wood.:cool: Every body says vinyl and plastic siding lasts forever till they put a BBQ to close to it and melt it ,nail it to tight and watch the ripples, weed wack next to it and chip the sh-t out of it , kids hit it with a ball and crack it in winter , and the best is to watch the mold grow on it and the way it stains so easy. :drink:
/ CEDAR SHAKE SIDING #6
We've had Cedar Shakes on the house I live in Dad built in 1953, and addition we added on in '64. Holding up great, but, need to be stained every 5 years or so.
I would say the most important factor would be the stain. If you are going with a colored stain, check to see if you can purchase a 100% oil base stain, not latex, something that will soak in the wood, to help preserve it. I will have to say it is better for bonding to the wood also. I'd advise not to buy the less expensive brand to save a few bucks, it could come back to bite you. The first oil stain that was put on, was made by Sherwin-Williams, and was great stain. Sometime in the 80's, they quit making it, probably due to the aluminum, and vinyl siding craze. A local hardware carried a decent brand oil stain, and it also seemed to hold up well. About 8 years ago, I went back to the same hardware, and got what I thought was the same product. Within 5 years, everything facing direct sun exposure, started rolling off. It wasn't due to high humidity, it was put on in Sept., our usual painting time when the humidity in low. Every other side of the house that doesn't get direct exposure was fine.
2 years ago, it was time to re-stain. Thanks to the internet, and a lot or reading on products,and their reviews, I finally decided on Cabot brand oil stain. Doing some checking, I saw 2 versions of the same product, so called the Cabot help line, to see what the difference was. The Rep explained that due to VOC laws passed in certain states, you are not able to buy 100% oil stain. But, their product is a "water encapsulated" oil stain, which I did not comprehend. She told me, "Imagine a bubble of oil stain, surrounded by a bubble of water. When you brush it on, brushing bursts the bubble of water, evaporating off, leaving the oil stain" I found that I could buy the 100% oil stain in a neighboring state 2 hours away, and thought it would be worth the trip to get it. She told me I could, but don't be caught with it here in this state, as there is a $10,000.00 fine, if they do. PER GALLON... In my mind, I kept picturing being in an accident, and a can popping open, Haz-Mat being called in, and me facing a $180,000.00 fine, so went with the water encapsulated.
I wire brushed, and wore out 5 stainless steel wire brushes, and 4 small screwdrivers cleaning the little grooves in the textured shingles, which took 4-5 time longer than the actual application of the stain. Due to the brushing, some bare wood was exposed, and routed out the soft cell layers in the wood. The first coat dragged hard on the brush. And, when filling the open cells, they would fill when brushing in one direction, and pull back out, brushing back the other way. VERY frustrating..!! I am assuming, due the the water encapsulating, and breaking that water bubble. However, the second coat went on, very easy, or as I would expect a 100% oil stain should.
I just re-stained a small building last week, going through the same process on it. I'd originally got enough stain to do the house, and that building. But due to the length of time it took to do the house, cool weather caught me, so put it off to last year. And last year,due to it raining most of the summer, through Sept., it got put off another year. We had the perfect weather for it, so got with the project. After finishing, I stood back, and compared the color. In 2 short years, it seem the pigment has faded a bit on the house, even in the not directly exposed to the sun sides. When doing the house 2 years ago, I got wire brushed down to the original Sherwin-Williams, and it's color
was as brilliant, or looked to be, compared to what was right beside it, of coats of other later brands. Sure seems to me, they sure don't make it like they used to.
/ CEDAR SHAKE SIDING #7
I don't know where folks are coming up with the requirement for staining cedar shingles.
The advantage of cedar shingles is that they DO NOT NEED any maintenance.
They naturally weather to a pleasant gray hue, and ..... FOR NO MAINTENANCE SHOULD BE LEFT THAT WAY!
White cedar shingles are used for sidewalls, red cedar for roofs. Reds last only 25 years on roofs.
I just had a new red cedar roof done. Labor intensive, thus expensive,.....but should last until I am 103.
This 289 year old house (built 1730), has never had any exterior siding other than white cedar shingles, allowed to naturally weather.
On South and West exposures, cedar shingles can last 40 years before requiring replacement.
On North and East exposures, up to 50 years.
Who could ask for more?
Absolutely NO MAINTENANCE,..... unless..... they have been either stained, or painted!
/ CEDAR SHAKE SIDING #8
I'm with fried 1765 on this. As a young man, our first house was cedar shake shingle roof and siding. After living there for several years I decided to repaint the side shingles. The original owner had painted it white. Being a newbie and DYI guy I tried to scrape the shingles and even took a propane torch to them. How dumb was I!!!
Cheers,
Mike
/ CEDAR SHAKE SIDING #10
I shingled the dormers on our log home with Red cedar hand splits with the express reason of never having to treat or stain it.
They are weathering nicely.
I used Red oak handsplits on the gable ends and had treated them with Cabot Clear Solution before installing about 15 years ago but have not retreated them since and they have darkened considerably since.
/ CEDAR SHAKE SIDING #11
Me too. Thought that was the whole point behind cedar. No maintenance.
/ CEDAR SHAKE SIDING #12
no maintenance is a FALLACY when it comes to cedar!. if it's stained, it gets bleached by the sun, and you'd think bugs and woodpeckers, and carpenter bees would stay away from it?, not a chance, My house has cedar shakes, and I get major problems from all three!.. Vinyl siding is the answer!.. forget cedar.. btw, forget trolls.. just noticed..
/ CEDAR SHAKE SIDING #13
I wonder just why this 289 year old house has had nothing but cedar shingles since the day it was built?
Must be because cedar is no good!
/ CEDAR SHAKE SIDING #14
I get carpenter bees chewing on my log home and woodpeckers rattling on my metal roof but so far no issues with the cedar shakes
/ CEDAR SHAKE SIDING #15
Yeah, a snow shovel falls against the side of a vinyl house and there is a hole in it! Not a fan of a plastic house. If you can afford a decent house, it's got to be stone!
I loved my Cedar roofs, but they simply didn't last. Now, I have one more to get rid of. Breaks my heart (and wallet). I'm jut guessing that when cedar roofs lasted a hundred years, the odd leak didn't bother anyone. Not like it messed up the drywall, or shorted out the flat screan TV. lol
/ CEDAR SHAKE SIDING #16
I think your climate and orientation to the sun makes a big difference. I have had 3 homes with cedar shingles. 1 had red cedar and they held up better than white cedar. The whites seem to dry out and curl in the sun. You can treat them but they still dry and split up here. If you get reds and put sickens on them, they really hold up well. My current home of 8 years now..I used all PVC trim boards. (Azak) and used cedar impressions ( vinyl ) ...unless you walk up to the house and touch the siding..you would have a very hard time telling it's vinyl...I just had it power washed a month ago and it looks new... For 400.00
/ CEDAR SHAKE SIDING #17
This squares with my experience. Although my barn is only 170 years old. The really old shingles have gotten thin where they were exposed to the sun but they still keep the weather out.
When I redid my house I bought shingles that had been dipped in Cabot Bleaching Oil: Cabot Stains Bleaching Oil Product | Cabot They seem to weather better and more evenly.
There is a bit of an art to installing them. If you're going to use a nailgun it has to be a siding gun, and it has to be one with depth control. I like my Bostitch n66c. If you're not doing enough to justify a $250 nailer hand nailing is not that bad, two nails per shingle. Around here it's code to use stainless nails but I've taken off a fair number of shingles and they all had plain steel nails, never had to do it because the nails were failing. In fact usually getting the old nails out is a pain. The exception is where the shingles are face nailed and the heads are exposed, even galvanized will rust, bleed and fall off fairly quickly.
/ CEDAR SHAKE SIDING #19
Are you referring to the old creosote-based stains they had 50-odd years ago? Yeah, they stood up well, but they were pretty toxic too. Back in the early-ish 60s my father had the bright idea to rent a sprayer to re-stain their house. Got the job done much faster, but the overspray droplets did a number on my mother's flower gardens (she was not happy), and I recall getting some on my skin and it burned for several days and didn't wash off.
Much as with lead-based vs today's paint, modern stains may not be as durable but they're less hazardous too.
I agree, you do need to shop carefully for a fully penetrating stain...it seems most "stains" these days are non-penetrating and don't work well on shakes.
Plan on getting a lot of stain...it soaks right in and you get a lot less coverage than you would for a similar amount of paint.
My house is about 100 years newer than yours. Dunno what it started out with for siding, but I'd say the shakes that are on it now go back a good 60-70 years. They're getting a little thin on the SW side, but the rest are in great shape. Even that side of the house will likely outlast me. They have been kept stained over the years.
When I re-sided my garage I left the shakes there natural. Wife kind of wants to stain them, but I like 'em the way they are. This far inland they don't turn that beautiful gray color they do near the coast, but still they weather nicely.
Vinyl siding, ugh. Ugh, ugh, ugh, ugh! Maybe OK on a house built in the last 40 years or so, but anyone who puts vinyl siding on a vintage house should face criminal charges.
I've never had problems with bees or woodpeckers, don't think we have carpenter bees this far north and the woodpeckers stay in the trees.
Someone mentioned brick. That seems popular in the south and parts of the midwest, probably makes sense where termites are a problem but it seems like it would be hideously expensive and not practical to install unless it's new construction.
/ CEDAR SHAKE SIDING #20
I forget what the stipulation was regarding the nails. I guess for starters, they had to be galvanized. Heard of shingles coming off, when the nails/or staples rusted off.
(4) 11R22.5 TIRES ON STEEL WHEELS (A64277)
(4) 11R22.5 TIRES...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
2017 EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
2017 EZ-GO SHUTTLE...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
