Insurance JD 2440 Hydraulic Fluid Alternative
/ JD 2440 Hydraulic Fluid Alternative #1
loganhorse
Reynolds station ky
John deere 2440
Is there a reputable but cheaper fluid over Hy Gard? Been seeing Harvest King John Deere at the local rural king.
/ JD 2440 Hydraulic Fluid Alternative #2
Bottom line, what is the dollar difference between your cheapest and what the HyGard will cost?
/ JD 2440 Hydraulic Fluid Alternative #4
I'd go with the Hy-Gard.. For only $25 difference.
Seeing in one of your pics from 2017 that you have Hy-Gard apparently when you changed out the fluid. How many hours since then that you are changing again?
Its self changing.....
No clue on the hours. I use it maybe once a month. Id say less than 100 hours since i changed it in 2017 when i acquired it. And I'd guess I've put 20+ gallons in it since then.
/ JD 2440 Hydraulic Fluid Alternative #6
I see, bad leak. Know where the oil is getting out?
Front around the pump I know. Was on the rear also but i have had it out today and haven't noticed it. Has hydraulic issues related to pressure also.
/ JD 2440 Hydraulic Fluid Alternative #8
Rear leak is probably draft sensing rod for lower links of the 3pt hitch, or breakaway coupler.
