Insurance JD 2440 Hydraulic Fluid Alternative
   / JD 2440 Hydraulic Fluid Alternative #1
loganhorse
Reynolds station ky
John deere 2440
Is there a reputable but cheaper fluid over Hy Gard? Been seeing Harvest King John Deere at the local rural king.
   / JD 2440 Hydraulic Fluid Alternative #2
Bottom line, what is the dollar difference between your cheapest and what the HyGard will cost?
Havest King - 45.99
Yellow bucket Extreme 334 - 34.99
Hy-Gard - $71
   / JD 2440 Hydraulic Fluid Alternative #4
I'd go with the Hy-Gard.. For only $25 difference.
Seeing in one of your pics from 2017 that you have Hy-Gard apparently when you changed out the fluid. How many hours since then that you are changing again?
Its self changing.....
No clue on the hours. I use it maybe once a month. Id say less than 100 hours since i changed it in 2017 when i acquired it. And I'd guess I've put 20+ gallons in it since then.
   / JD 2440 Hydraulic Fluid Alternative #6
I see, bad leak. Know where the oil is getting out?
Front around the pump I know. Was on the rear also but i have had it out today and haven't noticed it. Has hydraulic issues related to pressure also.
   / JD 2440 Hydraulic Fluid Alternative #8
Rear leak is probably draft sensing rod for lower links of the 3pt hitch, or breakaway coupler.
40' CONTAINER (A57192)
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2014 Deere 304K (A53317)
2014 Deere 304K...
Mailbox (A55853)
Mailbox (A55853)
Genie GS-1930 19ft Electric Scissor Lift (A55851)
Genie GS-1930 19ft...
UNUSED FUTURE FTJBD -32" MINI HYD MIXING BUCKET (A57193)
UNUSED FUTURE...
