Quick and dirty debris rake.
/ Quick and dirty debris rake. #1
herm0016
Carter lake, Colorado
Branson 4720h
Quick and dirty debris rake. Works a charm. Cost me about 3 dollars in bolts and a bit of flux core wire. Made of a window grate I had in the pile, and a stick of 3/8 x 3.5 plate from the stack of stuff in the garage. 1568412152059.jpg
/ Quick and dirty debris rake. #3
I could use that to pick up rocks in my food plots
/ Quick and dirty debris rake. #5
I love projects like this. Great work!
/ Quick and dirty debris rake. #6
I clear a lot of land, and so I went in a different direction in terms of rakes. I built a 3 point hitch, pin wheel rake with solid teeth and screening. The screening between the wheel rims allows soil to be filtered through, yet windrow the rocks. For areas of heavy limbs and woody debris that could get jammed in the steel screens, I put round discs on.
It is not super efficient because it only casts debris to one side, so I have to make a pass, the circle around, and then rinse and repeat to clear an area, constantly pushing the debris to one side until it is too big of a pile to push with my little tractor. But sitting on a seat and driving tractor in circles is a lot better then moving rocks and limbs by hand!
/ Quick and dirty debris rake. #7
Neat.
Hay rakes were often used in the past to windrow roots etc.
/ Quick and dirty debris rake. #8
That's pretty awesome. I don't know that I would have thought of something like that!
/ Quick and dirty debris rake. #9
Good work
Mine has a slightly different design that allows the blade to sit a few inches above the ground so that the tines can also work as surface rippers
NEW HOLLAND L228 SKID STEER (A64279)
NEW HOLLAND L228...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
PALLET OF EXERCISE STEPPERS (A64281)
PALLET OF EXERCISE...
(APPROX. 128) 1"X6"X8" PONDEROSA PINE (A64281)
(APPROX. 128)...
BUYERS PREMIUM & PAYMENT TERMS (A59914)
BUYERS PREMIUM &...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
