Comparison Cant Decide XJ2025 vs MT125
   / Cant Decide XJ2025 vs MT125 #1
Bwebbtx
Searching
So I think I have narrowed my choices down to the XJ2025 or the MT125. It would mostly be used for around the house digging, leveling ground, fence posts, scraping, and trenching.
I have been price shopping and the lowest I found on the MT125 TLB was $15,400 plus MMM for $1600 but when I went to the local dealer I sat on the XJ2025 and it got me thinking about going a little bit bigger. I do already have a mower to use so if I got the XJ I dont think I would mow with it due to the weight and having to take off the backhoe for the MMM. Pricing for the XJ2025 on a TLB was $18,200 +Box blade and Auger for $1200.
What I am wondering is, what is the biggest difference in capability for those 2 tractors to justify a $3k jump in price? Do those of you with the MT125 wish you would have gone up a little in size?
   / Cant Decide XJ2025 vs MT125 #2
That's a tough call.... I had my 125 for 2 years and 200 hours. Great little machine. Did a LOT of work with it, including doing a full septic system and grading an old abused gravel road. Used it to mow almost 10 acres (only a couple of times) with a 72" finish mower. It never disappointed me.
Then I got a bug that I would need a bigger tractor for some upcoming bigger jobs..... So I sold the 125 TLB and purchased an XG3025 TLB. Does it have more "umph" ? Yep sure does... The hydraulic flow is almost double the 125's flow, so much higher capacities. Comes in handy at times. Can I lift more weight/ quantity? Yep. Can I get into tight places like the 125? No. Do I now leave track marks / ruts? Sure do.
Do I regret getting the bigger tractor? No. Do I sometimes miss the little MT125? More often than I thought I would. I couldn't afford to have both, so the bigger tractor was a no brainer, one could always use a bigger tractor.
For the prices you were quoting, look into the new MT225e. Same HP, but much greater capability. The 225 can't accept a MMM, so probably not good for Mowing a small yard / area.
I know I didn't answer your question about the XJ2025 cost difference. It is bigger, little more capacities, bigger tires, little heavier. Is it worth $3K more? IMHO no. For around $3K to $3500 more, you should be able to get into an MT225.
I have heard the phrase here "buy once, cry once". I was fortunate to be able to sell my MT125 for just a little less than what I paid for it. That was why I was able to purchase the 3025. If I was able to get the 3025 initially, that would have been my choice.
Good luck in your search / purchase. Keep us posted.
   / Cant Decide XJ2025 vs MT125 #3
I know this is an older post (I'm a new LS owner, first compact tractor too), but I didn't find these two models to be similar at all. Compact vs. Sub, no? Am I confusing these two or did something change since 2019?
I went with the XJ2025 over the MT125 because it has over 250lbs more loader lift, and more than 500lbs of 3pt lift. It was about $3500 more, but that difference in lift seemed significant enough especially since I plan to use the loader w/ grapple a lot to clear woods. I was comparing the XJ2025 to the MT225 and other brands 25HP Compacts with the larger rear tire. Price & performance, the XJ2025 seems to be one of the best bangs for the buck out there.
   / Cant Decide XJ2025 vs MT125 #4
I went with the XJ2025 because it has over 250lbs more loader lift, and more than 500lbs of 3pt lift. It was about $3500 more, but that difference seemed significant enough especially since I plan to use the loader w/ grapple a lot to clear woods. I was comparing the XJ2025 to the MT225 and other brands 25HP Compacts with the larger rear tire. Price & performance, the XJ2025 seems to be one of the best bangs for the buck out there.
Welcome to the group.
   / Cant Decide XJ2025 vs MT125 #5
I had the identical decision to make. I went with the XJ 2025H for 1 big reason: The SSQA loader. I believe the loader lift capacity is larger as well. I have 5' & 6' buckets I use as well as forks. I am more than pleased. Good Luck.
Yooper Dave
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2012 PETERBILT 388 (A58214)
2012 PETERBILT 388...
3079 (A56857)
3079 (A56857)
8ft Truck Body Tool Box (A57454)
8ft Truck Body...
2025 GPS Trailer (A56859)
2025 GPS Trailer...
