Converting gas generator to Propane
/ Converting gas generator to Propane #1
shooterdon
Super Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
I cannot justify the capital cost and operating cost of a whole house standby propane generator. I no longer wish to store 200+ gallons of gas and cycle through it every year to keep it "fresh".
I have a Honda EB11000 and I am considering converting it to propane. Has anyone done something like that and if so, how did it work out? I see kits for about $200-300. I like the Honda as it works great, even though it is larger than I need.
My other option is to sell the Honda and purchase a dual fuel unit. These cost about $1000 for 7-8KW and that is all the power I need.
/ Converting gas generator to Propane #2
I suggest you look into consumption rates before converting.
I bought one of the cheap Duromax 10,000 watt (advertised) dual fuel generators 6 years ago. I tested fuel consumption with propane and gas before turning it over to my daughter. It consumed almost 6 lbs per hour with propane. On the initial run with one gallon of gas it ran 1 hour and 4 minutes. Both tests were performed at a constant 5400 watt resistive load. In actual use they were getting 10-12 hours on an 8 gallon tank of gas.
/ Converting gas generator to Propane #3
You will lose a little power/kw with propane but otherwise the kits work well. Very little maintenance once they are set up.
/ Converting gas generator to Propane #4
I bought one of the cheap Duromax 1000 watt (advertised) dual fuel generators 6 years ago. I tested fuel consumption with propane and gas before turning it over to my daughter. It consumed almost 6 lbs per hour with propane. On the initial run with one gallon of gas it ran 1 hour and 4 minutes. Both tests were performed at a constant 5400 watt resistive load. In actual use they were getting 10-12 hours on an 8 gallon tank of gas.
So.... you got a steady 5400 watts out of a 1000 watt generator? no wonder it has a 8 gallon tank.
My little Honda EU1000I will run somewhere around or over 10hrs on a gallon in eco mode.
My EU2000I uses a bit more but not by much
/ Converting gas generator to Propane #5
Propane is about 91,600BTU per liquid gallon, Gasoline is around 114,500 for summer gas winter is less.
So to produce the same hp it will take about 1 1/4 times more propane then gasoline.
Doing the conversion is not difficult and there are many kits available.
Some of the better ones will run dual regulators with the first suppling propane at a few pounds of pressure to the secondary which will be providing inches of water column pressure to the vapor carburetor.
Definitely a case of cheaper most likely isn't better.
Also be aware in cold weather a 20 or 30 pound cylinder or even the 100# may not have enough vaporization capacity to provide enough fuel to run a loaded engine, you may need a 100 gallon tank to have sufficient capacity.
/ Converting gas generator to Propane #6
Edited: I left out a zero. DUH!
I should have added that I intend to connect it to the supply line from a 500 gallon tank that supplies my house. Vaporization should be ok, but I do get down below 0* many times.
/ Converting gas generator to Propane #9
How much can you sell the Honda for? Seems like putting $300-400 into it when you can get a new one for $1000 does not make much sense. If you can sell it for $300 it is not that much more $ for a new unit.
Curious why are you storing 200 gallons of gasoline? Are lengthy power outages common?
/ Converting gas generator to Propane #11
How do the valves/valve seats cope with LPG.
I couldn't say with small engines but the truck and auto engines that run on unleaded gas do fine. They have all gone to better valves and seats.
/ Converting gas generator to Propane #12
Haven't pulled out my slide-rule to really check the #'s, but gut feel - if you needed 200 gallons of gasoline to meet your generator planned use, then you are going to have to upsize your propane storage capacity significantly. Unless you don't heat with propane.
If your road vehicles burn gasoline, consider splitting that 200 gal. in 2 or 3 time-staggered caches. With a good quality stabilizer, you'll be good for a while, and won't have to remember to burn up all that gas at once.
I like propane for what it is; I just think you'll need more than 500 gal.
Rgds, D.
/ Converting gas generator to Propane #13
Just that we have had two Landcruisers that destroyed the heads three times each, an 80 series and 100 series, I have heard that direct injection helps a lot but probably not practical on a small engine.
/ Converting gas generator to Propane #14
Not sure about F150, but I know gasoline Superdutys recently had a CNG/Propane prep option, which I believe included different valve seats.
Rgds, D.
A new EB11000 is about $5000...I hope to get $2500 for it. It is an industrial unit.
Minimum delivery is 150 gallons to my location. I never let the level in the tank go to empty. So I have 50-200 stored.
My reasons for going with propane is to avoid fuel storage issues, and not having to haul gas cans during the night or inclement weather. BTW, considering adding a second 500 gallon tank to get sufficient vaporization at below 0*, to have more fuel on site if SHTF, and buy when pricing is attractive.
if I sell the Honda for $2000, I can nearly break even with an 8000 watt dual fuel and reconditioned 500 gal tank.
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
Tube Line Trailer 5000 AX2 In-Line Hay Wrapper (A64911)
Tube Line Trailer...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2024 CATERPILLAR 299D3 XE SKID STEER (A65056)
2024 CATERPILLAR...
2012 MACK GRANITE-GU713 (INOPERABLE) (A67714)
2012 MACK...
