12 volt outlet
/ 12 volt outlet #1
MESSMAKER
Bluegrass,KY
DK4710SE
Anyone put an outlet on their tractor. I have a DK4710 and am unsure the best location.
/ 12 volt outlet #2
I have put a SAE battery tender outlet on the battery.
I use them to power up all my low amp devices on all my 12 volt items.
Very useful plug
/ 12 volt outlet #3
Eeny, meeny, miny moe, work's pretty well when faced with uncertainty such as that.
/ 12 volt outlet #4
Depending on what your wanting to use it for would have a lot to do as to where it was mounted.
/ 12 volt outlet #5
I'm unsure of your question as you haven't said what the outlet is for? What is the outlet going to power?
For example, I ran a wire directly from the battery to the back and below of my open-station seat. Used a weather-proof 'cigarette lighter' receptacle so that I can plug in the ROPS mounted amber Whoop-Whoop hazard beacon for the odd times that it's needed.
/ 12 volt outlet #6
WHAT? how are you supposed to light your cigarettes without a lighter? why didn't they include one??. find a spot that if your drill bit goes in too far, it won't damage anything!. and use 12 gauge wire to wire it.. if you use a marine grade outlet, it won't rust!..
/ 12 volt outlet #7
I put a waterproof cigarette lighter plug on the rear mudguard on my CK3010. I didn't have to drill anything or bolt it - there are a couple of holes there and I just used a cable tie. It to power a sprayer that I carry on top of the slasher (not when cutting obviously).
/ 12 volt outlet
I want it near the operator station where I can charge phone,run 12 volt air compressor,power sprayer and extra lights. I think it is an option. Where does Kioti put it?
/ 12 volt outlet #9
I'm not sure where kioti put it, but when I was doing mine I found spare wires on the right or left fender, and spare holes on both too,so you could fit on either side. I put mine on the right, but if you intend using a phone charger the left might be better as the phone could sit in the drink holder.
/ 12 volt outlet
Mounted very near the same place as you. I have two sets of extra wires near. I guess one is for worklight. I am not sure about the other. The first will only be hot when I have the lights on? The second set never seems to be hot. It is possible that I am not getting good contact. The plug ends are difficult to clean due to their location.
/ 12 volt outlet #11
I installed a lighter on my Cub Cadet Z Force mower where the correct size knock out plug already was. I wired right to battery with a fuse holder, 20A fuse right at battery +.
/ 12 volt outlet #12
I don't know if all kioti models are the same, but my CK3010 had a pair of wires on the right that are active when the ignition or acc is on, and on the left it has a white rectangular plug that is active all the time, even if the tractor is not running or ignition/acc is on.
/ 12 volt outlet
I will check and see if I have the same.
/ 12 volt outlet
I seem to have two sets of wires at the back of tractor. One is for an optional worklight and i am not sure about the other. I have checked the fusebox and they are hot but i am not getting juice at the plug ends. I have checked the fuses. What am I missing.
/ 12 volt outlet #15
They're probably hardwired to your light-switch so that you can turn the worklight on/off from there. That's the way it is on my 4105. OFF/Hazards/Front-lights & Hazards/Front-lights & Worklight.
I only have the one pre-existing wires/connection so I can't advise where your second set would be switched to.
/ 12 volt outlet
The second set was not labeled but was hot when the lights are on. That should work. I never could get the work light pigtail hot.
/ 12 volt outlet #17
I installed mine on the left hand side of my DS 4510 which is under the light / indicator/ horn switches. I ran heavy cable to accommodate anything straight to the battery with an in-line fuse . If my tractor is not used for a long period I can then plug in a small solar panel to keep the battery topped up as there is no shortage of sun here in Australia.
Pallet of Chains & Binders (A64127)
Pallet of Chains &...
2022 EZ-GO ELITE...
John Deere Pallet Forks (A66285)
John Deere Pallet...
2011 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64556)
2011 Chevrolet...
60in. Work Bench (A65640)
60in. Work Bench...
3269 (A63117)
3269 (A63117)
