CK2610 Operating RPM
/ CK2610 Operating RPM #1
Merc1100sc
Member
None
Hello all.
I own a 2017 CK2610HST TLB that I bought used about a year ago. Currently has 140 hours on it. Runs great.
My question is kind of vague. What rpm's do you guys typically run your tractors at. I believe the ceiling for this model is around 2600 rpm. During normal, not too heavy lifting work, I try to stay below 1800-ish. I feel like running it at it's peak is not good for it eventhough 2,600 really isn't a lot of rpm.
No right answer here, just looking for input for others on the same model.
Thanks
/ CK2610 Operating RPM #2
I have to run mine wide open to get 540 PTO RPM, if I am not using the PTO I run it below 1800 RPM.
/ CK2610 Operating RPM #3
PTO operation at rated speed.....non PTO work between 1800 and 2000 rpm. Keep the engine exhaust from building up soot and running regen more frequently.
Well that is what I've surmised from the many threads on this topic. Running FEL for dirt work 2,000 to 2300 rpm for the hyd. fluid flow to work loader and box blade.
When traveling to and fro set at 1500 and use the linked pedal to saunter to work site and allow engine to warm up the good times ahead.
/ CK2610 Operating RPM #4
I'd concur with that. Same with just about any equipment, regardless of size. I used to run my 2305 at much lower RPMs when transporting, and then give it a little when I was working it a bit....all the way up to full working RPM when shredding or using the finish mower.
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2015 Kubota L6060 (A64126)
2015 Kubota L6060...
2008 Kaufman Wedge Trailer (A62613)
2008 Kaufman Wedge...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
