Comparison kubota/ kioti specs and experience
/ kubota/ kioti specs and experience #41
Put some cheesie stick on chrome righten on it from the 60s and it will look EXACTLY like a Kubota! lol
/ kubota/ kioti specs and experience #43
/ kubota/ kioti specs and experience #44
Okkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk.
/ kubota/ kioti specs and experience #46
Op asked for experience and Koua provided it. Mr. Wolfe did the same.
/ kubota/ kioti specs and experience #47
It was just as helpful as koa telling how great his kioti was.
Well. I though my practical experience of owning both brands in the same HP class would be exactly what the OP was looking for. Why don't you go ahead and post your Kioti and Kubota owning experience so we all might glean some knowledge from you?
/ kubota/ kioti specs and experience #48
I test drove a Kioti, and no matter what I did, the loader was jerky moving up and down. So then I went to the Kubota dealer and fell in love with an mx5200. True story.
/ kubota/ kioti specs and experience #49
Strange I never had a problem with my Kioti loader or otherwise. I must be a smooth operator. lols
I did have a problem with a kubota jerky 3 point and the dealer bought it back. Good dealer he was.
/ kubota/ kioti specs and experience #50
Well my loader controls on my Kioti is a as smooth as a baby's bottom, and with my increased pump flow rate, I have enough flow to curl and lift at the same time, unlike the low flow rate in the Kubota it replaced. And don't EVEN get me started on the jerky 3pt hitch that Kubota puts on their so called "Standard L" models. And when the Regional Kubota rep tells you in a courtesy phone call that "if you had wanted a smooth 3pt control you should have bought a Grand L" That was the last straw. I bought a Kioti and swapped in the Kubota Standard L. If you would like to google Jerky 3pt hitch and the thousands of posts about that on Standard L series Kubota tractors feel free. It was a great topic of discussion here on TBN a few years ago, but I see you joined in June of this year, so you would not likely know about that.
/ kubota/ kioti specs and experience #51
Same with mine.
/ kubota/ kioti specs and experience #53
My front curl and lift are smooth and fluid also. Can run both at same time without issue. When I purchased mine the similar cabbed Kubota was 9 grand more for unit with same specs, but the Kubota didn’t come with rear wiper or rear remotes. They were extra.
/ kubota/ kioti specs and experience #56
Pretty much same story here... The Kioti just didn't feel right. Sorry folks. And BTW, all of my Kubota's run, work, and perform flawlessly... Does that help any?
/ kubota/ kioti specs and experience #58
OOOOKAAAY.
I Don't know why anyone would want to argue about the Kubota I had and the Kioti I have now. There is NO question about the FACTS I stated about the Kioti having more fluid flow, more weight, heavier axles and many many more features for about the same money as a Standard L tractor. (I gave $19,200 including the sun shade) These are just facts they are not debatable.
Because, as I stated above, often times it seems the unwritten rule here is: "Thou shalt not question the superiority of Kubota".
/ kubota/ kioti specs and experience #59
And your post is helpful??? Troll much?
Better then got out of my truck wife told me she didnt like it and I got back in and bought a kubota, love my kubota. Informative, really was.
/ kubota/ kioti specs and experience #60
Having 3 different Kubota's, my experience with them has been great if you can overlook their expensive leaky rear remotes and the inexplicable routing of the remote hoses under the Grand L series. I have an L4060 with a somewhat jerky 3 point. A very slight jerk but none the less, noticeable. Ive never seen comments on Kioti tractors concerning these issues. Thats my experience.
2022 EZ-GO ELITE...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
4" Makita Disc Grinder (A62613)
4" Makita Disc...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
Coleman Back Home Screen House (A62613)
Coleman Back Home...
