murphy1244
Super Star Member
- Joined
- Nov 25, 2011
- Messages
- 19,527
- Location
- Ohio
- Tractor
- Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
But JD has a copyright on the paint scheme.
Prove it
Prove it
talked to the owner of a kioti dealer other day which i happen to know(just came about wasnt in market for one), anyway he states that kubota is one of the lowest rated tractors out there as far as specs. says kioti has way higher lift capacties front and back and alot more flow as far as the hydraulic pumps. now i havent got into actual research of this myself, but was looking at some of your inputs for those who have owned/operated both and so on?? we do have a kubota now and have had for sometime, dont have to many complaints with it nice tractor. but when its time to replace wonder how much i should consider the kioti. is its usability as good or better?
This thread went off the rails pretty quickly.
A few weeks back I created a spreadsheet on all of the smallest compact 24-26 HP tractors (one size above sub-compact) each manufacturer makes. I too noticed that the FEL capacity on the Kubota B2610 was substantially lower than that of all of the competition other than the Massey 1526. The 3 PT lift capacity was squarely in the middle of the pack. The weight is second to the lowest of the 12 machines I compared. The Kioti CK2510 is the heaviest in the class I compared, but has the lowest 3PT lift capacity and an FEL capacity that is in the middle of the pack.
Loader Max lift may not be critical, but everyone is likely to compare numbers.* When I initially started shopping I focused on the L3301 and CK3510.* The L3301 is only capable of 1155 lbs while the CK3510 is 1860 lbs (50% greater).* There was no way I was going the invest CDN$24,200 for a tractor that could not even lift 1200 lbs.*Careful! Them there are fightin' words on this here forum. The unwritten rule seems to be "Thou shalt not question the superiority of Kubota".
I posted this comparison a little while ago (and was met with a torrent of derision). But, being an engineer, I tend to rely on hard numbers, as opposed to gut feeling and how things feel.
The plot below shows loader lift comparisons at the loader pin between a Kubota LA805 loader (spec'd out on a L3560) versus comparable loaders from other brands in similar sized tractors. While I don't have the full loader curves for all brands (kudos to Kubota for supplying it to their customers) you can compare the lift capacities of the Kubota at the same lift height with the other brands. If you're comparing Kioti to Kubota, a DK10SE series is very similar in frame size to a Kubota L3560. If you look at the green "x", you'll see the Kioti lifts about 46% more than the Kubota. That's an apples-to-apples comparison, and numbers don't lie.
Now, to get past the marketing hype, I think you have to ask yourself, "does it really matter"? For me, loader lift capacity was a major priority. I doubt that's the case for most people. As has been mentioned here already, high loader lift capacity does nothing for you if you can't keep the rear tires on the ground. This often requires additional ballasting, which may bring additional consequences (rutting in yards, the mess of filling tires and fixing flats, stress on axles, etc.). Only you can decide if that's important to you or not. As is oft-repeated here, I would make a decision based on what you need the tractor to do, not what it necessarily can do. If you don't need the loader lift capacity, or hydraulic flow, or whatever, why worry about it?
I do also, somewhat, agree with the comment that a dealer should be able to sell a tractor based on its strengths, as opposed to pointing out the weaknesses of others. It's one thing to present facts, it's another to try to use those facts to slander/bad-mouth another brand. You were there, so you know which approach it was. If it was the latter, I would be leary.
My 2010 Kioti DK45 cab unit was spaced to lift 2700 pounds. With rear ballast I have indeed lifted this much weight many, many times. I lift bags of concrete on pallets so I know exactly how much I am lifting.
Oh, bottom line: Is my Kioti a better tractor (at least for me and what I do) than the Kubota that it replaced? Yeah. In spades. It has many "luxury" features that make operation much better, It came with essential features like SSQA standard, It lifts more pulls more, flows more and is just "better" in all respects. Does this mean the Kubota was a "bad" tractor? NO not at all, but for me the Kioti offered more tractor for the same amount of money.
He is full of it. Kubota makes a good machine. Don't deal with a dealer that has to put other brands down to sell a machine
When I was looking to buy my first tractor for our property I looked at the Kubota MX5100 and a Kioti. The only reason I looked at the Kioti was because I saw the orange tractors and stopped, not realizing they weren't Kubota's. Anyway I was there and putzed around with one and just didn't care for it. I can't even remember what it was. My wife was with me, and she didn't care for them either and said, let's go back and buy the Kubota. I enjoy having all Kubota equipment and wouldn't have it any other way.
I am stull curious if Kioti would ever have gotten to where they are if they had chosen their "own" color?
Brain rot?
