Toolcat AC condenser
/ Toolcat AC condenser #1
DaveBittel
Toolcat 5610
I never have liked where the AC condenser is located on the Toolcats. I mow a lot with my 5610 and in no time my condenser was plugged to where I had to remove these air cleaner and fan an a few hours of washing and blowing it out. My "fix" was to put a piece of window screen in front of the condenser. Now when AC starts cooling poorly, I'll switch it off, open the access door and take the screen out and knock it off. AC works great again. Occasionally blow out the condenser but it hasn't been plugged since putting the screen on. The closed door just holdsd thhe scrwewern in place. The screen will. Ioften be poluggeed in under an hour. I also put on the air intake extension from Bobcat. Before my air filter would be plugged solid in no time when mowing. Picture is after about 45 minutes of mowing. Without the screen, most of fines would be plugged in the condenser.
/ Toolcat AC condenser #2
I wouldn't call this a bad solution,is just making the best of a bad desighn. Window screen covering a radiator or condenser drasticly inhibit's flow of air so should be avoided if possible. I'm not guessing at this or repeating what "Mr I Herd and Mr Tha Sayed" told me. You can see this for yourself while checking or recharging an air conditioner (tractor, car or home). Cover intake with screen and watch head pressure increase. Once again,what you are doing is better than doing nothing at all. Condensers should be mounted on cab but still require's diligence with maintenance.
/ Toolcat AC condenser #3
At day's end - wonder what your lungs look like........
Just making fix to poor design. I'm aware the screen isn't the best but it beats completed plugging the condenser weekly. To get it really cleaned out,I had to pull air cleaner box and fan to clean it from both sides. After a few mowings AC would barely work at all.
/ Toolcat AC condenser #5
I clean my tractor radiator twice a year. I don't have a rotary cutter of any kind. I first blow out the radiator - both sides. I've made an attachment for the air compressor. About 30" of 3/8 copper pipe with a 90 degree bend at the end. Run the compressor down to about 35psi. I'm able to reach all areas - both sides with this attachment. Then I follow up with a standard nozzle on the garden hose. Completely clean - even the dust.
/ Toolcat AC condenser #6
Bobcat has a side screen kit (7199661) that does about the same thing. I have a supply of paint filters that are the 5 gallon size, that fits the side door perfectly. After mowing, I shut the AC off and shake off the filter.
/ Toolcat AC condenser #7
I have the same problem- how do you get to the fan and back side of radiator, from underneath the machine.
I didn’t go from underneath. On my 5610, removed battery and air cleaner assembly and then could get to electric fan to remove it. I also had to pull out engine compartment access under front that front seat is mounted to. I mow a lot so I’ve also added the extended air intake kit.
/ Toolcat AC condenser #9
On our 5610 I removed the seat and the metal plate the seat mounts on, to access the relay that runs the fan.
/ Toolcat AC condenser #10
I have had a similar problem with my 2008 D series. This problem also exists with the air cleaner, engine cooler and hydraulic cooler.
I just cleaned my ac condenser as described in the post. It was extremely difficult to get too, primarily due to the lack of space to remove bolts from the fan housing and the bracket securing the air cleaner. Probably has taken me 6 hours just to get it apart. It sounds easy to do but it isn’t.
I’ve also decided to stop field mowing with the Toolcat- just too much damage, headache and heartache to the machine.
I’ll either have buy a tractor or hire the job done.
/ Toolcat AC condenser #11
Ps - you can’t get to the ac condenser from underneath unless you remove the fuel tank
/ Toolcat AC condenser #12
I also had debris clog the condenser. When I say "clogged," I mean that it could no longer work properly when the air conditioner was on. And it gets clogged from the system, not being able to properly distribute air through the cabin when cooling. When the engine is running, when the air is hot, the condensate from the evaporator evaporates and settles on the heater radiator, air conditioner evaporator, and air ducts. Aircon leaking water most of the time cannot be fixed at all. When the air conditioner turns on, it starts blowing dehumidified, cold air. That's when the condenser gets clogged (discharged).
/ Toolcat AC condenser #13
I have a 2007 5600D, do a lot of mowing, and for fourteen years have stopped every few hours, brushed debris from the screen, and blown the unit out with compressed air thru the screen at the end of the day. Have never had a problem. Have I just been lucky? Is this adequate maintenance? Do I need to be doing something more? I do the same with the radiator/oil cooler.
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
New Quick Attach Hay Spear (A65563)
New Quick Attach...
JMR 4ft Tree Boom Skid Steer Attachment (A64553)
JMR 4ft Tree Boom...
2016 BMW X3 SUV (A64557)
2016 BMW X3 SUV...
HEAVY DUTY MILITARY TENT (A63276)
HEAVY DUTY...
2022 EZ-GO ELITE...
