Challenger MT285B 3 Point hydraulics
   / Challenger MT285B 3 Point hydraulics #1
Gr8Jeepin
Member
Clay, NY
none
I while ago my father was felling a tree and long story short it fell the wrong direction and landed on the 3 Point skidder. And after that the 3 Point won't lift. It does have an external lift cylinder. I wasn't sure if it had also had an internal lift mechanism. Where would be a good starting point to diagnose what is broken.
On another point, is there a procedure to change the hydraulic fluid and filter?
Any help would be greatly appreciated. Thank you
   / Challenger MT285B 3 Point hydraulics #2
By looking at some pictures I don't see a an external lift cylinders. I would say the rod went thru the piston because a spike like that would over ride the safety valve.
Do you have a parts diagram, or the exploded view of the internals?
It appears that the Massey 1547 is the same tractor. So hopefully parts are easy to come by.
   / Challenger MT285B 3 Point hydraulics #4
No I don't. Put most 3points work about the same and have for many years.
2025 TMA Attenuator Truck (A52377)
2025 TMA...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
2010 COMPTANK ACID TRANSPORT TRAILER (A55745)
2010 COMPTANK ACID...
