Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #5,011
Wow !! are you sure your tractor is powerful enough to push that thing full of snow. That is a big snow pusher.
44 hp gross, 42 net, four cylinder. It does my hills in high gear too :)
I love this mule as it has load sense & linked throttle to HST.
I will not know until winter if I have enough traction...using back blade and retaining wall bricks for rear ballast 800#.
Prime says the snow pusher only weighs 625# but it looks heavier..lol
   / Pictures of your snow weapons #5,012
That pusher looks HUGE! The PO sure took good care of that tractor.
2012 with 187 hrs on it when I purchased. :)
   / Pictures of your snow weapons #5,013
no one else saw the big block V8 snow blower?. THAT is HUGE!.. it comes with either wheels or tracks..
   / Pictures of your snow weapons #5,014
I guess we will have to wait till winter to know for sure. Let us know then how it performs
   / Pictures of your snow weapons #5,015
I think the tractor will push it. The weight is probably similar to my 8' Fisher plow setup. I have grooved the tires, and it makes a difference in traction. This is the second tractor with R4's that I've grooved. I haven't had a real pusher, but did add wings to the loader on my L3200. It worked OK.
The one drawback was that it would only move snow in pretty much a straight line. For short runs it was fine. I do parking lots at the church and the thing would fill and spill before getting to the end of the lot if I took wide bites.
With the angling plow, I can drive the length of the lot casting snow to the side and clear the whole lot working from one side to the other. For driveways I can get close to the garage doors and backdrag away from them.
   / Pictures of your snow weapons #5,016
I push with a hydrostatic 3038e, 6ft snow pusher. Set the rubber blade 3/8" above the shoes and it catches no gravel, dream to use.
No problem on stock R4's running 16 psi in the rears, and 750lbs 3pt Ballast.
   / Pictures of your snow weapons #5,017
Running it that high off the surface, and never scraping do you run into the problem of having such a thick base of snow that in the spring it turns into a solid sheet of ice when things start warming up during the day and freezing at night?
   / Pictures of your snow weapons #5,018
No not at all, the push weighs about 800lbs, it usually cuts trough right through to the bottom. In the spring i have about 1" of hardpack over the grass. As soon as the spring sun hits it, it disappears pretty quick.
I get zero gravel in my snow piles.
But also i live in Alberta Canada, Global warming has not come here yet.:laughing:
   / Pictures of your snow weapons #5,019
Yeah, you're lucky up there, you get a real winter and can establish a thin plow base (I happen to like snow and cold, which not everyone agrees with). I'm in a part of VA where we can get decent snow falls, but there will almost always be a thaw within a week. Sometimes the thaw happens the very next day!
   / Pictures of your snow weapons #5,020
Here is what I’ve used last 4 to 6 years and here is my new one.
Jim.
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
Ford 641 Workmaster (A50514)
Ford 641...
2013 Nissan Juke SUV (A50324)
2013 Nissan Juke...
