Buying Advice L3560HSTC suggestions for recommended options
   / L3560HSTC suggestions for recommended options
The dealer still hasn't been able to get one in. They got one but it was already sold. May have to look at other options as I have some projects I need to get done.
   / L3560HSTC suggestions for recommended options #22
I just received my L3560 HST C last week. Got the big loader (LA805) with the 4 in 1 bucket and the OEM 3rd position option. Had a 60" Woods Brush Bull, pallets forks and a hydraulic (angle) dozer/snow blade already. Bought a radio from Messicks that has the wiring all set up for the tractor.
   / L3560HSTC suggestions for recommended options #23
Technically that is the medium loader for the Grands. You can only get the big loader (LA1055) on the L4760 & larger. They upgrade the axle & tires at that size, so presumably that's the weak point(s) on the smaller Grands.
   / L3560HSTC suggestions for recommended options #24
Actually, it (LA805) is the big loader for the L3560. You can get a larger loader on the other Grands, but you can also get larger loaders on M, M5, M6, etc. so he did get the big loader for his size tractor.
   / L3560HSTC suggestions for recommended options #25
I would like to know how you like the 4 in 1 bucket after you get a few hours with it. I've wondered if it would be worth the money?
   / L3560HSTC suggestions for recommended options #26
Congratulations. You will enjoy the cab.
   / L3560HSTC suggestions for recommended options #27
Very much this. I was moving some logs around the other day. It was 90+ outside with very high humidity and I didn't even have to have the ac fully cranked. On the 3301 I would have been drenched in sweat.
Get some sort of antifog spray for the inside of the windows if you operate in high humidity. I use rain-x.
Congratulations! I heard from my dealer yesterday and the tractor is there now, just waiting to be setup and checked out. Sounds like you are good to go. How long did it take to get yours, or did they have it on the lot?
   / L3560HSTC suggestions for recommended options #29
Something that you might want to consider doing to your tractor to protect the radiator. Will be installing mine hopefully this afternoon after work.
   / L3560HSTC suggestions for recommended options #30
I have all of 10 hours on new cabbed tractor with a few more to come tomorrow. It is amazing to be able to spend half a day working at the property and feel great when I’m done. It has turned August work into a pleasant experience.
White 5100 / 6900 Planter (A59814)
White 5100 / 6900...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
John Deere 4600 (A53317)
John Deere 4600...
2020 John Deere 1025R MFWD Compact Tractor (A56438)
2020 John Deere...
2018 Dodge 5500 Bucket Truck 4WD (A56438)
2018 Dodge 5500...
