What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #761
Nothing particularly productive.
Cleaned out the radiator screen again. Sadly even with the FEL up the screen does not pull straight out with R1s, have to force over tread unless turned exactly right. I can see doing my own split screen at some point.
Also replaced my rear stabilizer that I found. This time the pins are safety wired to reduce loss.
Couldn't you just jack the front of the tractor up a few inches and pivot the left tire down?
   / What did you do on or to your LS Tractor today? #762
I think a split screen might be more user friendly out in the middle of the field
   / What did you do on or to your LS Tractor today? #763
A few more hours brush hogging and killing some albizia trees
   / What did you do on or to your LS Tractor today? #764
Actually seen two regens. 1st about 17 hours, 2nd about 35.
Wow David i suspect you are doing a lot of idling the engine or working at a reduced rpm, pick the engine speed up and you will see higher hours on your next regen, i try to stay close to 2000 rpm as possible by down shifting to a lower gear. My 1 regen was i think 40 hrs i have since picked the rpm up a notch.
   / What did you do on or to your LS Tractor today? #765
Thanks Walt,
My only idle time is a bit of warmup when I start and before shutting down. Normally running at PTO speed. When not mowing I might be a few hundred less but not usually, just turnoff PTO, raise 3pt, shift into 2nd range and head shed. The regens don’t last long, a few minutes, yesterday @ 51.5hr maybe 2-3 minutes. Was just below 2500 rpm and mowing. Maybe I need to go back and read manual, but thought that was the recommended.
   / What did you do on or to your LS Tractor today? #766
Thanks Walt,
My XR4155HC had regen. cycles at 50.0, 100.0, 150.0, and 200.0.
   / What did you do on or to your LS Tractor today? #767
Thx but I need my thought together ahead of time.
I need to see what I want, the Manufacturer doesn't need state a selling price but at least what is the MSRP.
Im glad that LS dont have big fancy web sites because all that stuff comes at a cost and i dont want to see LS cost more ! I got my tractor for about 4k less than what all the other LS dealers were advertising them for because my dealer when i went in and asked questions the salesman understood price was a key factor for me! He offered to look around and see if he could get a dealer trade of a 2018 when the 2019s were already available of course everything was exactly same between the years but it gave him room to cut price a lot it was also with a 8ft box blade and a demo use only bush hog ! So all together probably saved 6k all this could not ever be in a built your own web page and no matter what you order your tractor with you will probably find something that you forgot in the first year lol thats when the dealer you used will be the important part! Im 1.5hrs from the dealer i chose to use and there is another one 50min away but that one the salesman was not interested in trying to save me as much as he could only interested in selling tractors! So dont let less internet pretty web pages sway your opinion of LS go test drive some and see who you will be dealing with when you need or want their help!
   / What did you do on or to your LS Tractor today? #769
Today got back from 1200mile trip to go pick up my new baler and did a little bit of grease on it now just need a manual for it so i can get it tip top! Also pulled some t posts with front end loader still have hundreds to pull and reuse to get layout of pastures better!
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
(5) CANDY JARS (A58374)
(5) CANDY JARS...
(3) DRILLS (A58374)
(3) DRILLS (A58374)
2019 TAKEUCHI TL8 SKID STEER (A52709)
2019 TAKEUCHI TL8...
500BBL WHEELED...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A57453)
2007 International...
