Premade 3 point ballast customization
/ Premade 3 point ballast customization #1
HawkinsHollow
SE TN
Branson 3015R
So I saw this ballast on Craigslist.
The seller says it is 600 pounds. My tractor probably need 1000-1200 pounds back there. What do ya'll think about encasing this ballast in concrete to get it up to 1100 or so pounds? Could I make it thick enough to not crack and break apart?
/ Premade 3 point ballast customization #2
You could always weld some pieces to it on the back for your concrete to be supported by and give it a good anchor point.
/ Premade 3 point ballast customization #3
What I did once to add weight is go to the local metal recycler and buy lead ingots. Not expensive, very dense, easy to bolt on and handle.
Hmmm, interesting! I might try that.
The guy is asking $175 for the ballast, I think I could get him down to $150. I like the compactness and how the weight is carried low.
