How to dig a pad?
/ How to dig a pad? #1
DIESELbowhunter
PA
John Deere
Hey guys,
This weekend I am going to start excavating for a 18X24 run in style shed. The area is somewhat level, and rocky. My goal is to remove top soil, maybe 4-6? Then bring in modified to fill back up, then have the structure built. I will have Two John Deere 4310´s on-site. One with a loader and a backhoe. One with a loader/grapple and box blade. Never really digging a pad like this before, what would be the best way to use these two machines to accomplish this? Ripping up the area with the box blade scarifiers then removing with loader? Backhoe? Looking for any tips, tricks, and basic excavation strategy ideas for this. Thank you
/ How to dig a pad? #2
I've got a similar project coming up so I'm interested in the answers too.
/ How to dig a pad? #3
If its a pole structure, the ones I've seen, the don't bring in the fill or concrete until the frame is up and the base sideboards are in.
/ How to dig a pad? #4
Pics might be helpful
/ How to dig a pad?
Here is the best pic I have right now. All wood is already removed from area . It wont be a pole like building it will just be resting on the stone. D3D04921-CB4E-43C6-8B33-AD0666E6450A.jpeg
/ How to dig a pad? #6
I cleared an area for a 30x40 pole barn with a box blade and tooth bar on my bucket.Single bottom "potato" plow my be used to break the sod.Just did the same for my 24x32 pole barn this summer.
/ How to dig a pad?
Thanks for your input. In this situation is is best to dig a general area, about the size of the tractor, to the desired depth then work your way in?
/ How to dig a pad? #8
Here is the best pic I have right now. All wood is already removed from area . It wont be a pole like building it will just be resting on the stone.View attachment 617170
Top soil is organic material that is decomposing that you cannot compact. I do not see anything that looks like topsoil in your picture. Do not remove virgin ground. It is VERY VERY hard to get new fill dirt to compact anywhere near as good as virgin soil.
What is your drainage situation? In most cases, it is better to bring in fill to build up a pad so water runs away from it. Even better if you can just remove some material from around the sides of where the building is going to be to increase drainage and not touch the soil where the building is going to be. Spray round up and be done!!!
/ How to dig a pad?
Hi Eddie,
Very interesting. To be completely honest with you, I am not really sure why I automatically assumed it was actual topsoil. I am new to the property and from what I’ve been told, that area used to be wooded and over the course of 30 years, big trees were removed and became the overall area to process firewood. As far as drainage goes, I’ve never seen any water puddle there and everything dries up pretty fast in that section of property so I definitely agree with a raised pad. Assuming no soil needs to be removed, what would the best action be then? Just flattened/level, maybe a little modified ( I prefer that surface inside ) and build? Here is a picture of what is to be built 7F402E6C-40AA-4F0E-86FA-E8F04AC6141F.png
Again thanks for everyone’s help. New homeowner, new tractor owner, nooby here ��
/ How to dig a pad? #10
I'm assuming from the picture that no posts where set in the ground, which is why they have those beams going across the ground. Do you plan on drilling holes into the ground for posts? This will tell you more about your soil then anything else.
Here, where I live in East Texas, we have mostly red clay and something called iron ore, which is red dirt mixed in with lots of tiny rocks, some that have enough iron in them to be picked up with a magnet. There closest thing that we have to top soil is where the leaves build up in the trees, but once you rake up all the leaves, you are on solid soil.
Back in CA, where I'm from, it was all topsoil that was called loam, and it grew the best crops, but if you went up in elevation, the soil became rocky and there was no topsoil. Before they went crazy with Code and Earthquakes, foundations where minimal.
From what I see in your pictures, I would drill the holes for the posts and start building.
/ How to dig a pad?
There are no posts that go into the ground. I’m having an Amish builder come and erect that building. I believe he prefabs most of it in his shop and puts it together at the location. Today when I get home from work I’m going to take a good look at what kind of soil I’m dealing with.
/ How to dig a pad? #12
I put a big pole shed up at my my new home and told the track hoe to make a pad for the shed. He said all the top soil was removed already from a previous owner. All he did was have a foot of crusher gravel brought in and his rid on vibratory roller pounded it down. When they got done I had a very difficult time digging for sewer lines it was packed so tight. Your picture looks like there isn't any non packing topsoil on the surface.
Make sure it is elevated enough that any drainage water won't touch the building.
/ How to dig a pad?
2 votes for not even needing to remove soil. Something I never even considered. Thank you !
/ How to dig a pad? #14
Add another vote to dig in the posts and add crushed rock to elevate and level.
/ How to dig a pad? #15
I also concur. Level what you can with stone AFTER you’ve placed your posts. Looks like that ground is pretty solid. And you’ll know once you start placing posts.
/ How to dig a pad?
So the building itself is not going to have posts in the ground. It just rests on the ground. I’m getting it from an Amish builder and I believe he prefabs most of it then delivers it and puts it together. I took a better look at the ground I’m working with and I think I will definitely have a very thin layer of soil I’ll need to remove ( maybe just a couple inches ) . I recently had some stumps ground in that area and looking in the hole the grinder made, I was able to see the different layers of soil. This thin layer is probably just from leaves, and the small debris left from wood splitting sitting for years.
/ How to dig a pad? #17
I'm curious why you are getting a building that is sitting on beams instead of having one built with poles in the ground? The difference in strength is significant. The only reason that I've ever heard of for building on beams is to be able to move it around, but that speeds up the deterioration of the building, and most of the time, they rarely get moved because it causes so much damage to the building.
/ How to dig a pad? #18
I agree with Eddie.
I would add that if you don’t want posts in the ground, possibly look at concrete piers to set posts on.
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
Tennant T17 (A64127)
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A65643)
2017 FORD F-150...
