Bridge I-Beam cutting.
/ Bridge I-Beam cutting. #61
Nice work, Deere Dude. That’s way better than the one’s we built years ago for heavier loads and longer spans.
/ Bridge I-Beam cutting. #62
Looks to be 16'-ish long, the I-beams with red arrows look spliced and the green one looks like C-channel with added flat bar............ If it was 25' I would have a 3" pitch in middle. So far looks good, dont forget to post the bridge when it's planked over.
/ Bridge I-Beam cutting. #63
That turned out great. How deep is that canyon?
OP here
Eddie; The canyon or gully from bottom to bridge is 8-9 feet. Needed a 7' step ladder to put bolts in center. I used half of an extension latter to get in the gully. I will get a couple completed pics when railing are painted.
Old Path; I can assure you every beam was a 20' I-Beam and every one has a 3' 9" I-Beam piece welded on the end making overall length 23' 9+" using 7018AC rod. Each weld has a 2 foot or so 5 1/2" plate welded on the top or bottom and both sides of each beam have a foot long piece of 5 1/2" plate welded to it. Two beams needed a heavy angle bolted to it at the end so the wood would sit flat on something as in the orange beam.
Both outside I beams have two 1-1/2" angle iron welded together , side to side, with predrilled holes and the angle side without the holes was welded to the top of the beams. From the end view the angles look like a T with one side welded to the top of the beam. This is so I would have a flat surface for bolting to wood. I didn't have any 3" flat stock for bolts so I welded two angles together.
I don't understand the 3" pitch advice. The top end header has a 5" angle iron and was flat but the lower head angle iron warped in the center when welding it together so is lower in the center. When I noticed the warp I left it. Ran out of ambition to cut and reweld. Water still runs off it.
The top end of the bridge is maybe a foot higher than the far end. Flat and level would be better but I didn't want to dig down much on the high end or add much fill on the low end.
/ Bridge I-Beam cutting. #67
I am in the beginning stages of building a 12x24' bridge across a gully. I have 6 8" 20' I-beams I need to make 24' long.
That means I need to cut another one into 4' sections.
I don't have a torch, bandsaw, plasma cutter or anything fancy. I do have 4-1/2" grinders and chop saws and a couple hundred HF 1/16" abrasive discs for the handhelds.
My question is, would it maybe better to use 4-1/2" abrasives or get diamond discs. I am sure diamonds discs would last longer, but how much longer. If a lot better then I will run down to Home Depot Monday and get a couple or a few. They are about $13 each. I am sure they would be safer from the shattering aspect.
View attachment 579391.
Any other ideas about cutting other than the ones mentioned would be helpful. I need the cuts to be fairly straight because I need to butt weld them. I will weld a plate on the sides of the joints also.
Just crank up the amperage and use your 1018 rods with your arc welder to sever to pieces
/ Bridge I-Beam cutting. #69
Good looking and substantial bridge
/ Bridge I-Beam cutting. #70
I wonder what cost more, the beams, the boards or the bolts........... Are you paint the bridge or are they pressure treated lumber?
/ Bridge I-Beam cutting. #71
Wow, DD! Nice job. I'm very impressed! Not sure I would have tackled such a job.
/ Bridge I-Beam cutting. #72
Looking at the newest pictures and I really like how it turned out. Perfect place for a bridge. Hopefully you'll post pictures of it in the future with water running under it!!!!
Okay, so I had time today so I gave my new bridge a somewhat real test. I hung a plumb-bob from a center beam to a a little above a rock in the dry creek bed and and took a measurement. Then I drove my JD 3730 with 7' finish mower on it along with a full bucket of fill type dirt and parked in the bridge center. Maybe 5-6000#. Went down below and the height difference was less than an eighth of an inch. I could have read it wrong, but either way it didn't have any discernible sag. I don't plan on driving a 20k unit over it at any time so I am happy with it.
/ Bridge I-Beam cutting. #74
Looks good!
Will.... BE GOOD.....until you buy that full size TLB that many of us would like to have.
/ Bridge I-Beam cutting. #75
I didn't see anyone mention it, and it's too late for this project anyway, but a
propane tip in an OA torch would let you use propane bottles from a BBQ pit...
still need the oxygen though
/ Bridge I-Beam cutting. #76
Your bridge turned out awesome! Nice work.
You would cringe if you saw the pseudo “bridges” we drove 10 ton trucks over on our various farms in the old days.
/ Bridge I-Beam cutting. #77
Good way to test the bridge. Congrats on a well thought out project!!!
2010 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
30x57 Welding Table (A65640)
30x57 Welding...
2022 EZ-GO ELITE...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
White Oak Slabs (A65640)
White Oak Slabs...
