JD 500A 24v charging system
/ JD 500A 24v charging system #1
corcom
coopersburg, pa
8n, Ford 3000, JD500A
I bought a used JD500A diesel backhoe around 20 years ago. Really nice machine. Other than regular maintenance, hose changes and etc. no real issues. Of course I don't use it much as well... The one issue is the system charging. To begin with, the wiring behind the front panel has decayed and so I dumbed the system down. I've got the starter hooked up. The only other thing hooked up was the alternator. However, it hasn't been charging for years... It's a 24v alternator (Motorola RA24JD902) landing on one of the 12v battery's neg terminal (two 12v batteries in series). There is a red and blue wire coming out of the regulator going to a plug on the harness. The blue wire broke and so I finally decided to try to figure out what's going on. With the engine running I tried measuring voltage from the regulator outputs to ground and got no reading on either the red or blue. Am I doing something wrong or is the regulator kaput?
/ JD 500A 24v charging system #3
My advise from serving as a JD dealer service manager from 1976-1987 is to change your 500A electrical system from 24 volt to 12 volt. if you follow these instructions you will probably not get BALD from pulling your hair out.:D
/ JD 500A 24v charging system #4
/ JD 500A 24v charging system #5
:welcome:
Welcome to the forum!
I'm going to move this thread over to our John Deere section.
Thanks for responding Tx Jim. I guess it would be a lot simpler doing 12 volt. I don't use the backhoe often and not when it's below 50. Though I had to once get it started after a big snowfall and so rigged up a platform to aim a torpedo heater at the block for about half an hour... But otherwise I just need to crank the starter - that's it. Fuel gauge doesn't work - a dipstick works fine for me. The only rub is I'd have to switch out batteries (I'm assuming 2 sixes in series), alternator and starter?
/ JD 500A 24v charging system #8
just wire the battery's in parallel no reason to switch them out
I missed the obvious! Thanks LittleBill21.
/ JD 500A 24v charging system #10
Don't think Catherine noticed you already had a duplicate thread started in the JD Vintage tractor section.
/ JD 500A 24v charging system #11
Welcome to TBN
I advise to change 24 volt elect system over to 12 volts & save yourself a lot of grief. I served as a JD dealer service manager from '74-'87 & I'll bet I understand the quirky JD 24 volt system much better than the average member of tractor discussion forums. Does your tractors electrical system have 2 large circuit breakers that were field installed that help keep wiring from shorting out & causing a fire?
Sorry about the muiltiple posts. This is my first time and I'm just figuring out how this works. Definitely haven't seen these breakers.
/ JD 500A 24v charging system #13
I switched my Dynahoe to 24 volts,
I used a 24 volt one wire alternator similar to this;[
I just picked up my 12 volt lighting off of one battery.
My system is a negative ground so my alternator is wired to the starter hot lead.
On JD 24 volt system that I'm familiar with one can't successfully have elect accessories connected to just 1 battery as the batteries will not charge back up correctly IE the elect accessory load must be split equally between both batteries.
/ JD 500A 24v charging system #14
No worries :)
I merged the two threads that had posts.
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A64556)
2018 GMC Sierra...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2008 Case CX240B Hydraulic Excavator (A64194)
2008 Case CX240B...
Kewanee 12A Cultimulcher (A66408)
Kewanee 12A...
AR500 Deer Target (A65640)
AR500 Deer Target...
