Tractor suggestions for primarily snowblowing a long, steep, windy driveway?
   / Tractor suggestions for primarily snowblowing a long, steep, windy driveway? #42
Turns out CalG was correct. I measured with that app and the steepest spot was 20 degrees shown in the photo I posted. Just beyond that is only 15 degrees. About half of what I was told. Handy app, thanks for the recommendation.
20 degrees is 35+ percent grade....still very steep when icy.
   / Tractor suggestions for primarily snowblowing a long, steep, windy driveway? #43
Not very impressive, I have not used a tractor mounted snowblower and only done minimal with a walk behind.
I do know with that amount of snow any of my tractors and blades or even the old plow trucks would have done that faster and cleaner.
Do you guys think a 2013 husqvarna GT 48XLS with a 48" snowblower would handle this task? Tractor has 27HP. Seems too cheap to do what I want, but then again, I know nothing about tractors.
   / Tractor suggestions for primarily snowblowing a long, steep, windy driveway? #45
You said it....
   / Tractor suggestions for primarily snowblowing a long, steep, windy driveway? #46
A lot of those Husqvarna’s have problems with the frames bending. Also, a lawn mower type 2 wheel drive will probably have troubles pushing the snowblower back up the hills, without a lot of spinning. Where are you located ?
   / Tractor suggestions for primarily snowblowing a long, steep, windy driveway? #47
I expect that it would do the job, lets see the first pass would be 48" wide, the rest would be considerable less I would expect, maybe 30-36 inches.
So haw many passes do you wish to make?
Also they most likely will all have to be made working down hill,
also I expect that chains will be required to climb back up your hill.
Six to eight passes at what 3 mph out in the cold, windy, and wet weather, would be a few hours of time.
If you don't mind getting cold and wet and taking a long time to do the job, enjoy.
Also I wouldn't expect that unit to last more then a few years.
My quarter mile drive with an "S" turn takes about an hour at least with 8 and 10 foot blades,
the corners take quite awhile to push out as they are so tight that plowing around them doesn't work well.
   / Tractor suggestions for primarily snowblowing a long, steep, windy driveway? #48
I like the idea of a side by side cabbed with a blower and it's own motor, warmth, a capable 4x4 UTV that you can chain up, light on pavement, it's good math IMO and I have considered that option..
   / Tractor suggestions for primarily snowblowing a long, steep, windy driveway? #49
It's down to the pavement. How much more do you want it to do? The OP already has a gator that makes it up and down his steep paved drive. Many people are telling him to get a tractor and chains. He has a small budget. Why add a tractor to the mix if he could just add a blower to the gator?
2018 John Deere 7230R (A53317)
2018 John Deere...
2017 John Deere 30G Mini Excavator (A55851)
2017 John Deere...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
UNUSED WOLVERINE TDB-11-78W 78" BUCKET (A57193)
UNUSED WOLVERINE...
2011 John Deere 7430 Premium (A53317)
2011 John Deere...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
