Break Away Test
/ Break Away Test #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
Hi TBN'ers
Can one test the function of the Break Away system by simply pulling the key out of the switch with the trailer not connected to the tow vehicle? Shouldn't one hear the electric brakes 719.JPG722.JPG engage? I know the battery is okay (new), but the indicator lights on the box don't light up; as though the battery indicators are dead. I've checked the continuity of the ground wire, but ain't all that savvy with wiring.
Cheers,
/ Break Away Test #2
It will work connected to the tractor. Pull the pin the brakes should lock up. I don’t think you can check it without tugging on it.
/ Break Away Test #3
If you keep having trouble, I might be able to come try to help.
/ Break Away Test #4
Jack the wheels up on one side and see if they turn. That’s how they do my safety inspection on my trailers.
/ Break Away Test
Thanks gents,
I'll try the jack up one side ASAP and get back to you.
Cheers,
Mike
/ Break Away Test #6
Can't you just pull the pin, then drag the trailer while watching to see if all 4 tires are dragging?
/ Break Away Test
That would work as far as I know, if the trailer was hooked to a tow vehicle (working by himself), and could actually see the wheels. Right now it is parked. Heck I was thinking that one could pull the pin, while parked, and just "hear" the brakes engage. But I'm doing other chores the past/present few days and don't need the trailer right away. Thanks Reb
/ Break Away Test #8
Try it on gravel, drag it about a foot or two then get off and look, you should be able to see the gravel torn up behind the tires that are working.
/ Break Away Test #9
Set your phone video up beside the tires. If the wheels spin, the brakes aren’t locked.
Also, are you sure the brakes don’t have rust in them?
/ Break Away Test #10
Assuming that they are electric brakes. With the pin pulled, place a magnetic compass near the hub (NOT the one in your phone) and the needle will point towards the brake if the magnets are energized.
/ Break Away Test #12
You can here them some times, but the click may be only 1 engaging. The fool proof test is to jack one side and check each tire like already stated. Then you know for sure that each one is working properly.
/ Break Away Test
Jacking a parked trailer is not that difficult. That sounds like the surest/easiest test for me.
Thanks,
Dftodd
/ Break Away Test #14
Thanks,
Dftodd
Your welcome. I've come behind someone at work where they "checked" the brakes by listening for the click. Only one side was working. The other side was so rusted up that I had to replace the brake assembly.
Other time, they checked a set of hydraulic surge brakes by just engaging the brake away. That one had a crimped brake line so it was tight and had plenty of pressure. But wasn't actually engaging the brakes. That was on a piece of towable equipment that weighed 10,000 lbs. If someone lost it, the person who said the brakes were good would probably be in jail if someone got seriously injured.
/ Break Away Test #15
Please note - all the electric brake controllers I've installed over the years have stated that you should never check a breakaway while the trailer harness is hooked to the vehicle - could fry the controller. Just be sure the harness isn't plugged in to the tow vehicle. Those batteries don't last terribly long, usually I get 3 years out of mine and I keep it on a 10w solar charger indoors when not using the trailer. It will barely buzz the magnets on my 2 axles even with a good, fresh charge but it does work at least.
/ Break Away Test #16
My GooseNeck breakaway switch at least half a dozen times on hard corners etc. It didn't fry anything but not saying it can't.
When jacking the trailer up, built up rust may make you think brakes are working but in reality may not be working very well. IMHO the sure test is when hooked up trying to pull when the breakawat cord is unplugged. You can unplug the 7 pin cord if you want to, unplug the breakaway and step on the gas. You should be dragging the trailer.
/ Break Away Test #17
My GooseNeck breakaway switch unhooked at least half a dozen times on hard corners etc. It didn't fry anything but not saying it can't.
IMHO the sure test is when hooked up trying to pull when the breakaway cord is unplugged. You can unplug the 7 pin cord if you want to, unplug the breakaway and step on the gas. You should be dragging the trailer.
/ Break Away Test
Several good ideas from the TBN'er, as usual. So far I have not got back to installing a new breakaway kit. The old kit may be okay, but I just decided to get a whole new set up.....along with some covers for the trailer tires. My old ragged tarps that cover the tires fell apart. That e-trailer outfit is quite efficient and helpful for trailer needs.
Cheers,
Mike
/ Break Away Test #19
Here in Washington County, NY when Sherriffs do a truck inspection in the rest area just down from our house with pickups they jerk the brakeaway clip out and watch for skidding tires, or tickets may ensue.
Pair of 480/80R36 Tires (A65640)
Pair of 480/80R36...
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
Skid Steer Hitch Plate (A65640)
Skid Steer Hitch...
2021 Ram ProMaster 3500 Box Truck, VIN # 3C7WRVLGXME588513 (A65563)
2021 Ram ProMaster...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
2003 International 4300 Bucket Truck (A62613)
2003 International...
