Tired of cleaning Diesel soot of FEL (Kubota B2650)
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #1
Pabco
Member
Meadow Vista, CA
Kubota B2650 / FEL LA534 / BH77 BH
Got tired of cleaning soot off FEL from engine exhaust stream. Made the following mod:
Cut off about 1.5" of existing exhaust pipe (after removing spark arrester @ end);
Cut down a standard 1 1/4 EMT prebend conduit as necessary;
Drill tap a couple of new holes. Problem solved.
Total cost: $7.50 (beats the $95 version available on the net).
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #2
Not concerned about it stirring up a lot of dust ?
Bill rob: it’s not really that close to the ground. Just tested it. On semi hard pack nothing on powder top soil it does throw out some dust between the back of the FEL and in front of my front tire. But in powder the rest of the tractor is kicking up dust as well. I suppose I could add a real short 45 degree bend or turn the pipe up a but more. I’ll post if I change it. I could also add an A/C cab... :thumbsup:
Decided to use the full length of the 1 1/4" EMT pre-bend 90 degree fitting. Needed to add another 5 degrees of bend or so, but now it blows the exhaust nicely above the ground between the FEL and in front of the front tire. :thumbsup:
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #5
I wonder if that could increase the temperature of air going through the radiator and affect engine temps.
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #6
with that added extension i would be concerned about interference w/debris & branches, etc esp w/fel raised
Diesel - the air flow is behind the radiator grill and blows past it nicely.
BB - Good point. The 1/4 steel bracket and clamp make it extremely strong though. I specially don’t have a lot of wooded areas where I tractor, but if I did I would have designed it differently for sure. Again, good point.
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #9
nice job. are you bending pipe yourself, having done @ muffler shop?
BB - Went to a local muffler shop. $5. :thumbsup:
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #11
Be happy you have soot versus the issues the Tier 4 final engines have. I'll take visible particulates (soot) over all the emissions junk anyday.
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #12
I had the same problem,$5.00 at the local muffler shop for the whole shebang! It does kick up some dust but that is easier to clean off than soot. I finally adjusted the exhaust outboard about 45 degrees.
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #15
very slick indeed
Very nice. Any (exhaust) problems while using backhoe?
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #17
As you know heat rises and may also warm your hydraulic fluid and hydro transmission.
Depending on where you live that could be a issue or maybe even a benefit in really cold areas.
Not saying its wrong or bad rather something to monitor to see if it has an effect or not.
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #18
Fixed mine too, now just have to watch for low limbs, the canopy is about the same height.
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #19
Interesting thread; I have never had any exhaust problem. Granted mine is tier 4, but look how it flows. Exhaust goes right in front of the tire and behind the FEL.
/ Tired of cleaning Diesel soot of FEL (Kubota B2650) #20
Try searching eBay for "silicone turbo hose coupler"
it will come up with all sorts of hoses, straight and bent, that can be used to extend the exhaust, yes, they can withstand the heat,,
Many cost less than buying the same thing in steel,
The BIG benefit is that if you hit something, the silicone will bend like rubber, and flip right back to original shape,,
Many people have ordered a size that is a little tight,, then you do not even need a clamp,, :thumbsup:
If I were doing it, I would probably end the extension with one of the reducers that would bell out at the end,,
The tractor would look like a kids Cummins powered Dodge pickup,,, :laughing:
2012 Toyota Camry Sedan (A61569)
2012 Toyota Camry...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
Toro z turn (A56859)
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2014 LONE STAR TRAILER 18 T/A TRASH TRAILER (A60736)
2014 LONE STAR...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
