2011 Kubota L3940 fan belt squeal
/ 2011 Kubota L3940 fan belt squeal #1
okgat
Member
Hi,
Fan belt squeals loudly intermittently. The fan belt has never been replaced. Will someone please describe how I am to check if the fan belt needs to be replaced and how to replace it if necessary.
Thank you. RG
/ 2011 Kubota L3940 fan belt squeal #2
Hi,
Thank you. RG
I have attached belt checking and tension instructions for a model almost the same as yours.
The recommended maintenance is to check every 100 hours.
If after you tension it correctly, it still squeals, you need a new belt. However, when the belt is off, check that the pulley's it drives turn freely. The engine crankshaft pulley wont turn as it drives the others.
Dave M7040
/ 2011 Kubota L3940 fan belt squeal #3
The deflection specs for belts are commonly at 10 or 22 lbs of force. "Moderate thumb pressure" isn't very accurate though it's what many people go by. You can buy actual belt tension gauges.
Thank you both for helping.
2021 YANMAR SV40 EXCAVATOR (A59823)
2021 YANMAR SV40...
2005 Isuzu NQR 4 door box truck with folding gate (A61307)
2005 Isuzu NQR 4...
2006 International 4300 Altec LRV58 58ft Forestry Bucket Truck (A61568)
2006 International...
Iranch IRET13 Electric Tricycle (A60463)
Iranch IRET13...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2024 Linx 7'x18' Trailer (A60463)
2024 Linx 7'x18'...
