L2501 grill guard question
/ L2501 grill guard question #1
garbageman
Orange County, NY
Kubota 7500
Just noticed I cracked the plastic grill on the front of the tractor
I have seen several YouTube videos on building a metal grill guard
My question is what gauge of the expanded steel should I use?
Thanks
Ray
/ L2501 grill guard question #2
Thanks
Ray
Made mine from 1/8" raised expanded metal.
I tend to go heavy because I do a lot of tree and brush work.
/ L2501 grill guard question #4
Mine is a lot like wagne223. It's split near the bottom to allow the grill to fold forward.
/ L2501 grill guard question #5
B26 brush guard.
Absolutely necessary for brush work. Found some scrap SS expanded metal at the scrapyard, $2. 3x5” angel at bottom to prevent sticks from coming up. Haven’t used hitch like I use on the bucket. Maybe a tie down point for trailering?
Recently busted the plastic grill on my M59. Had bought heavy rock quarry screen to weld to brush-guard but haven’t got around to fixing. Now have more work to do. Have used perforated metal to repair plastic grills in the past and will be doing again. Kubota had a factory option of a heavy metal hood guard that bolted/hinged to the factory brush guard for the M59. Never seen one except for pictures but like the idea of added protection.
/ L2501 grill guard question #7
Mine ain't a 'bota but this one is 1/8" plate :) I've smacked it with a couple good ones at least 4" in diameter and held up fine.
/ L2501 grill guard question #9
we used 9 gauge expanded metal and it is plenty stout. Cost about $80 if I recall, used non-flattened carbon steel
/ L2501 grill guard question #10
That piranha bar sure makes brush and tree clearing so much easier. See the need to improve the grill guard.
If your are going to use Piranha bar type equipment or grapples, improve the grill guard first. Lesson by experience.
/ L2501 grill guard question #12
Again, I was very fortunate. Just about the time I purchased my grapple there were a couple threads on TBN about damage to grills, radiators & batteries. I had my grill guard installed prior to the dealer installing the grapple.
Oosik
Did you purchase your guard from the dealer? Was that a Kubota option?
I was planing on fabricating something
Ray
/ L2501 grill guard question #14
I think mine was 1/8” as well. Works really well.
/ L2501 grill guard question #15
garbageman - the basic grill guard is a Kubota option. Just FANTASTIC for stopping thing the size of garbage cans and larger. The expanded metal and design was by a young fellow at the local welding shop. He wanted to paint the "tongue" red and paint a big white eyeball up in each upper quadrant.
/ L2501 grill guard question #16
I put some flat 3/4 expanded metal on my l3901 grill guard and contoured the top to match the cross bar radius. So far it’s held up really well.
Thanks
Kholer Magnum 10 Compressor (A63118)
Kholer Magnum 10...
New/Unused Landhonor Quick Attach Power Rake (A61166)
New/Unused...
CAT 930M (A58214)
CAT 930M (A58214)
2015 Ford Escape SVU (A61569)
2015 Ford Escape...
2014 BMW X1 S Drive 28I SUV (A61569)
2014 BMW X1 S...
2022 CATERPILLAR 299D3 XE SKID STEER (A62129)
2022 CATERPILLAR...
