Cleaning up 5 acres
   / Cleaning up 5 acres #1
Capstone
Kaufman, TX
LS MT125
Hard to believe we baled hay here when I was a kid. There was one large Honey Locust (huge thorns) tree at the back of the property. Fast forward 30 years and 80%+ of the small trees in the foreground are Honey Locust.
Hired a forestry mulcher for 8 hrs to get rid of most of them. You can actually see the pond again.
Before and after:
Thorns EVERYWHERE. Got a subcompact (LS MT 125) and have started the cleanup.
Raking in reverse and watching for thorns as I go.
I fully expect an invasion of Honey Locust shoots next spring. I think they’ll be under control in a year or two between mowing, spraying, and the cleanup crew.
The cleanup crew
   / Cleaning up 5 acres #2
Those honey Locust are bad news.
Cleanup crew looks anxious to get started.
How much did the hydro axe cost ya for 8 hours?
$150/hr. He was half the price of two others I called. Would have been worth it either way...he did in a day what would have taken me months to do.
   / Cleaning up 5 acres #4
Did you get the tires filled? Be careful either way, the R4s may not stop those thorns.
Not filled but dealer put Ultraseal in them. I think there are very few tires made that could stop those suckers. Being extra careful - last thing I want is a flat on brand new tires.
   / Cleaning up 5 acres #6
You're definitely gonna test Ultraseal!!!
I have took out Honey Locust trees. Simply doesn't phase em. The roots shoot up new trees.
I cleared half a dozen large ones in a fencerow 8 years ago. They still shoot sprouts 50ft away in the field. I diligently spray the new ones each Spring. I've saw no less numbers each year.
I think the Mulcher will make this much worse. Anxious to see the results!!!! Thanks for posting the pics and your progress.
Get out of here with that kind of talk!
Only positive, anti-Honey Locust thoughts allowed in this thread.
But do you have my secret weapon? Black belly sheep...browsers.
   / Cleaning up 5 acres #8
I know, I'm sorry, sometimes reality hurts!!! :)
I think Honey Locust shoots are so prolific that even the sheep will get tired of eating the leaves. After all,,, I love a good Steak but don't want to live on Steak alone. :)
So the one large HL when I was a kid was actually just across the fence on 100 acres we leased. Developer bought the hundred acres and took down the HL. The result was our 5 acres full of them.
I sprayed about 50% of the cut stumps with Remedy after the mulcher was done. Hoping that will kill some of the root system.
Time will tell.
   / Cleaning up 5 acres #10
Time will tell.
Yep. You've already witnessed how they spread under ground. It's the damnedest thing I've every saw. Much worse than Eastern Red Cedar.
I use Remedy to spray the sprouts and it works great.
I removed my trees with a backhoe. Completely removed the stump and all exposed roots. Sure surprised me that they are still sending up shoots years later..... :(
HUDSON BROS 9 TON PINTLE HITCH TRAILER (A52708)
HUDSON BROS 9 TON...
2006 APPA TL (A55787)
2013 John Deere 350G LC Hydraulic Excavator (A56857)
2013 John Deere...
LOT: Tap & Die Set, Hole Saw Set, Snap Ring Plier Set (A59076)
LOT: Tap & Die...
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
