Rotary Cutter Say No to Rear Bands on Rotary Cutters, Get Chains!
   / Say No to Rear Bands on Rotary Cutters, Get Chains! #11
It doesn't seem like chains would work for the 2" saplings I hog.
It handles it with absolutely no problem. I've cut 3" stuff easily, some times even 4" going a bit slower.
We do mow a lot slower because most of the time we are just backing up against brush higher than the tractor. Sometimes there are some hidden surprises there like open old water wells anywhere from 6 ft to 15ft wide.
Here is a video. Not mine and it's a bigger JD though but doesn't matter anyway.
Limpeza de Terreno em SIntra muitos carrascos - YouTube
   / Say No to Rear Bands on Rotary Cutters, Get Chains! #12
Chain guards are a must on mower IMO. We only have mowers with chains guards here. We also use chains instead of blades for the cutting, that will throw big things, really far away. A band guard wouldn't last 3 hours.
It won't get all bent up when reversing over hidden stumps, rocks and etc.
It allow for a better spreading of the mowed stuff.
PLUS 1
   / Say No to Rear Bands on Rotary Cutters, Get Chains! #13
I've been looking at rotary cutters for several years now. Just can't swallow that large $$$ outlay and pull the trigger. I see the advantages to chains and would be getting them on anything I would purchase.
I just wonder - why is a set of chains so God Awful expensive. Right now my choice would be - Rhino TW35 @ around $4000. A set of chains for this cutter would add almost $1000.
YIKES> set of chains $1,000 bucks.
Bush Hog wants $400 for a set of rear chains for my 5’ SQ160 Squealer
   / Say No to Rear Bands on Rotary Cutters, Get Chains! #15
Thanks for the good explanation and the video says it all
gg
   / Say No to Rear Bands on Rotary Cutters, Get Chains! #16
This just reminded of how my grandfather had his rotary mower set up -- which if I'm recalling correctly was with short blades connected to the spindle which then held a chain with a set of Y-shaped knives (like would be on a flail mower) at the ends.
Thinking about it how, I'm realizing it was a rather interesting setup compared to current retail rotary cutters. Not sure if he bought it like that or if it was something he did on his own. In fact at the moment I'm realizing just how many interesting items he had on his farm. A propane-powered Farmall 300 with wide front (as opposed to the standard tricycle), and the old IH two point fast-hitch system that was also compatible with standard 3pt hitch implements, and a 70's-80's era IH hydrostatic tractor with loader (can't recall the model though it was probably in the 7500-10k lb weight range).
Any way, back on topic I almost think I'd go rubber guards over steel bands just for this reason ....and the about the only reason I'd consider either of those options over a chain guard would be if I had to worry about bystanders or nearby vehicular traffic within the distance it'd take for an ejected object to fall back to ground level.
...but that's just me and I tend to be a bit ....different. :D
   / Say No to Rear Bands on Rotary Cutters, Get Chains! #17
Funny how the thread morphed into using chains for cutting when I believe origin thread starter was about using chains instead of band around rear (skirt?) of mower to protect from having it throw things out by blades and from band getting bent in to hit blades...
Dale
   / Say No to Rear Bands on Rotary Cutters, Get Chains! #18
I'm not trying to be argumentative, but the video makes that hogging look labored. As a matter of physics, there is no way that chains could be as effective on large diameter material as 3" or 4" long, 1/2" thick, swinging blades on a rotary cutter. For instance, my cutter is 3" x 1/2" in cross section and have much much more weight and inertia behind them, and when I back into a swath of 2" to 2.5" pine sapplings that are 8' tall, my hog makes them disappear in seconds. Now I agree that chains would be handy when dealing with foreign objects and unknown materials on unknown land, but there is no way that they could be as quick and efficient as rotary blades.
I should make a video to demonstrate what I'm talking about. Unfortunately I've had a tractor mis-hap, and it might be a little while.
   / Say No to Rear Bands on Rotary Cutters, Get Chains! #19
This is the second cutter I have seen on line using chains rather than blades. Sure not the same person. No doubt heavy chain rotating a high speed would do a lot of damage to small trees and while we don't have much of a rock issue here would be safer. The chains would have to be on the short order of they would drag unless rotating rather fast and if not short enough they could not touch each other they would have to get tangled upon start up.
   / Say No to Rear Bands on Rotary Cutters, Get Chains! #20
I understand your reservations. I had it myself before I tried it.
When I had the smaller Kubota B7000, I built the mower for it and at the time I just made my own blades, which worked just fine. Then I upgraded to this bigger tractor and bought a mower for it, that come with the chains, like 95% of mowers here. The difference on the ability to mow bigger and thicker stuff was just night and day for the type of brush with deal with.
I don't claim that the chains are more effective than the blades. Most likely it isn't, since you need more HP, although it pulverizes and spreads the mowed stuff better. But chains is what works better here, with our type of brush, terrain and all that stuff. Blades is probably what fits better the US stuff.
This is the cheapest option for land clearing, then we have the bigger flail mowers, but that is an entire new game with all the options for blades, hammers and so on.
20724 (A55853)
20724 (A55853)
1981 AZTEC SKINNY NECK 31 FOOT FLATBED (A55745)
1981 AZTEC SKINNY...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Fork...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55301)
Kuhns AE10 Small...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A53422)
2006 International...
GROUND PROTECTION PAD 8X4 15 COUNT (A55745)
GROUND PROTECTION...
