Echo chainsaw won't tight chain
/ Echo chainsaw won't tight chain #1
tradosaurus
Super Member
Texarkana, TX
Kubota MX5400 HST, heavy duty bucket, 3rd function, R1 tires (rears filled), 2 remotes
I had to bring my Echo chainsaw in under warranty a few months ago because the tightening screw was stripped. After it was fixed I made sure to be careful not tighten it too much.
Today the chain was loose and the screw would tighten anymore.
I'm wondering if I am doing anything wrong? I'm going to bring it in today to have it look at but I really don't want to have to shut down my chores because of this.
I guess I might need to buy a second chainsaw as a backup.
/ Echo chainsaw won't tight chain #2
What model? I just bought a 051 I think. Are you talking the hand knob?
/ Echo chainsaw won't tight chain #3
No need to buy a 2nd saw.. just get a tutorial on the proper way to do it.. & buy an extra chain..
Some of those videos on u tube might help.??
I learned a thing or 2 by just reading the instructions on the package my new chain came in.!!
Update: I brought the chainsaw into local dealer and he showed me with a new chain that my existing chain was stretched. I believe what is happening is that by not cleaning the bar of the chainsaw enough oil isn't getting to the chain for lubrication and cooling thereby causing the chain to heat and stretch. He also replaced the chain gear that was wearing (probably due to oil deficiency.)
I still might buy an additional chainsaw as if I'm going to spend 2-3 hrs cutting I don't want to have to stop for adjustments and sharpening.
/ Echo chainsaw won't tight chain #5
Does the saw have an adjustable oiler? I have never cleaned a bar in my life and never had this issue, The chain should stretch a little when new after a couple of tanks of fuel..
/ Echo chainsaw won't tight chain #6
The chains tension needs to be adjusted through the course of the day, and certainly when you replace a chain. The bars channel also needs to be cleaned out on a regular basis. I only do that when the chain is being replaced.
/ Echo chainsaw won't tight chain #7
additional chainsaw
I don't sharpen my chains as the local shop does a great job for only $5 and is right behind the grocery store of the same name.
Instead, I have three chains for each of my saws; I've found that lets me have plenty of fun without stopping much and if I only go into town once a week I'm usually OK on sharpness.
(Of course, I'm an intermittent sawyer; if I used my saws much more I'd probably start sharpening my own.)
/ Echo chainsaw won't tight chain #8
Are you loosening the bar nuts before adjusting the chain adjuster? Otherwise the adjuster has to work a lot harder and will strip.
I have multiple additional chains for all my saws so I can just put on a new sharp chain and keep working if one goes dull in the middle of a job. Unfortunately, frequent chain adjustments are part of the deal. I use the chain adjuster every time I change or sharpen a chain, which is at most every 2 tanks of fuel. I also clean the bar out and turn it over to even out the wear every 2 tanks or when I sharpen the chain.
When I was running a saw 8 hours a day I adjusted the chain at least once a day. Then and now I carry a T tool with me.
/ Echo chainsaw won't tight chain #9
If this helps. Here is photos of the bars clutch cover and chain guide being cleaned out today. Of course this is a pole saw, but its the same. In the 1st photo, note the clutch cover covered with debris. Then cleaning. The bar oil holes also need to be cleaned, after the chain guide was cleaned.
/ Echo chainsaw won't tight chain #10
For a 2nd saw, 501p Echo is not bad, I bought one 4 months ago, it's a good saw so far, has adjustable oilier so it can put out all the oil I need and then some. A 2nd saw is almost a necessity.
/ Echo chainsaw won't tight chain #13
firstly, adjust the oiler to maximum flow, oil is cheap chains and bars and sprockets soon add up. then once you fire up the saw rev the engine with the chain a few inches of a block of wood or piece of card board or newspaper page or some other surface so as you can see oil droplets flicking of the tip of the chain, when this happens your chain is being lubed and ready to cut, it it isn’t investigate why. of course be aware of kickback.
contrary to popular misconception chains dont stitch, they do wear however by the pin bushes elongating. having said that i haven’t ever had a chain wear out faster than the cutters.
always back the chain off after completion of work, when the chain is working it will warm up expanding it, then when it cools down it can contract, this is why you generally need to nip up the chain a little bit once you start working., the consequence of this can bind up the chain or worse still crack the crankcase housing.
2015 Chevrolet Silverado Pickup Truck, VIN # 1GCNKPEH7FZ334229 (A65563)
2015 Chevrolet...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
2011 FORD F-150 (A65643)
2011 FORD F-150...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
1968 MTTI Lowboy Trailer (A62613)
1968 MTTI Lowboy...
