ROPS collision
/ ROPS collision #1
GamblerAcres
Member
Ohio
2018 Kubota MX5200
2018 MX5200 purchased new. Made it all of 85 hours before I ran into a barn header board today with the ROPS. Looks like it bent back a little. I couldn't find any cracked welds or metal. Should I be worried? Feel like a dumbass.
/ ROPS collision #2
I would check the mounting plates and bolts. Unless you really were moving doubt you did any real damage to it.
/ ROPS collision #3
Neighbor had a new B series Kubota delivered several years ago, Dealer dropped it off, neighbor decided he didn't want it to see the rain.
Jumped on it and headed for the garage ---- UH OH, we had to let the air out of the tires and use a floor jack to raise the door header.
Had label made and placed on dash "LOWER ROPS APPROACHING GARAGE".
Looks to be minor bend, I'm sure that the ROPS will take more.
Designed for a rollover.
JW5875
/ ROPS collision #4
It doesn't look to bad,I wouldn't really be worried about it that much,those rops are pretty tough.
I did almost the exact same thing on a carport about 26 years ago all it did to the rops was a little scuff mark.busted the top header board though.
/ ROPS collision #5
Only took me until the 2nd day. Ran into garage header. Front wheels came off the ground, ROPS not affected at all. Good dent in the stucco to remind me now. :eek:
/ ROPS collision #6
Are you sure it bent back? Many ROPS come sightly leaned back from the factory. They're really sturdy- thick wall large diameter tubing and thick mounting plates that tie into the axle or transmission. They're designed to support the entire back half of the tractor when it rolls over, with a significant overbuilt safety factor. It'd take a real hard hit to bend one.
If it was bent, it'd be bent more on one side than the other. From that pic I don't see that, but it's just one pic.
/ ROPS collision #7
If it was bent, there'd probably be a stressed area where the paint started to flake off. Check the mounting plates where it bolts to the frame.
If you don't see that, don't worry about it. If you do see that, I still wouldn't worry about it.
I did the same thing to my GC1720 with 12 hours on it. I actually ended up ripping the front fascia off my garage when I tried to back out while panicking after the initial hit going in. I felt sick about it for a while but couldn't find any evidence of bending. I checked squareness with string and everything. Now I just don't care.
/ ROPS collision #8
I have a new B2650 and my ROPS appears to be at that exact same angle. Most of the Kubotas that I have seen are angled back a bit. If you bent it, it would likely be out of square, is it?
/ ROPS collision #9
First time I pulled the M into the drive shed, I smacked the cab roof into the rafters [tractor was too tall] and smashed a huge hole in the plastic cab:mad:
Ran all winter with a bituthane patch and then did a permanent epoxy/fiberglas cloth repair in the spring.
/ ROPS collision #10
I doubt any damage to it. As stated above, the paint would have flaked or wrinkled. I doubt the bolts stretched, but you could check tightness to confirm.
/ ROPS collision
It very well may have been like that from the factory but I don't know for sure because I never really checked until now. It definitely flexed backward because I could see it flex forward when I reversed away from the board. I was hoping others would chime in saying theirs looks the same
/ ROPS collision #13
This might help a little.
Idk. Looks like the one you have may be a touch swept back. Its really hard to tell.
/ ROPS collision #14
The "flex" you saw may have been the front end getting light or rear tires compressing a little, then when you backed up, the front settling or the rear tires unloading. I doubt it flexed and did not leave any evidence like damaged paint or stretched bolts (you did check them for tightness?)
/ ROPS collision #15
I don稚 think I would worry about that much.
My rops is at about the same angle as that, since I bought it new. They are designed to take much more abuse than that.
/ ROPS collision #16
It wouldn't have been much of a ROPS if you indeed damaged it from that.
/ ROPS collision #17
Well - it looks the same as mine on the M6040. And I've never hit anything with it. Check that your mounting bolts are tight and don't worry about it.
I don't have a picture of the one stall on my carport where I kept my first tractor( Ford 1700 ). Fortunately the "header" is just for show. It is a 140 year old - 1" x 10" rough sawn board. I hit it with the roll bar - didn't even slow the tractor down. I was lucky. The board didn't hit me when it fell. I patched it with a chunk of plywood. It's been up there, patched, for over 36 years. I moved the tractor operations to my one carport bay with a 16' high ceiling after that.
/ ROPS collision #18
Double check welds bolts,doesn't look like any damage...part owning tractor. ;)
/ ROPS collision #19
Did that the first two hours on my new tractor. Luckily for me, it was a board inside the barn (2"x10"). Snapped it like a toothpick.
My father-in purchased a new JD 4052M that wouldn't fit in the garage with the ROPS up. It was destined that he would tear down the garage with the ROPS up. Therefore, I put a tennis ball on a string that hung down to his nose to remind him when he hits the tennis ball.
In looking at the pictures, I don't think you bent anything permanently. You may have temporarily flexed the ROPS but it looks like it went back into position. These things are tough and are built for rolls and tumbles. Any bend could be a liability on the company in the event of a roll. They may be designed to flex to prevent a "break" or bend.
/ ROPS collision #20
Had a neighbor with a Ford 4600 European model with the ROPS posts and metal canopy (rigid structure) moving hay one day. Must have been concentrating on something else as moving forward, he contacted a horizontal limb of about 8" in diameter catch his canopy and almost flipped him over backwards as he was getting lined up to stab a bale with his 3 pt spear. Don't know if he had to head to the house for a fresh change or not but he hasn't done it since....for one reason he called me over to cut down the tree for my firewood. Gladly accepted the offer.
2007 Imperial 25 Ton Tri Axle Tag A Long Trailer (A61568)
2007 Imperial 25...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2017 Ford F-150...
UNUSED RAYTREE RHBC72-72" HYD BRUSH CUTTER (A62131)
UNUSED RAYTREE...
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A61165)
2004 International...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
