JD MFWD on 2720
/ JD MFWD on 2720 #1
suburbanfarmer
Western NY
JD 3238e & 3228e
As you all know I am new to tractors and was doing some loader work today in so called 4wd. I got the front tires spinning and noticed that only the right front spins. The left front was not spinning at all.
I then engaged the diff lock but that only locked rear 2 tires.
Is this how mfwd is supposed to work or do I have some issue on the left front axle drive?
/ JD MFWD on 2720 #2
Yes. The front doesn't benefit from the diff lock, nor have its own diff lock.
Be careful not to engage the diff lock while the tire(s) is spinning.. could break something.
/ JD MFWD on 2720
So in some cases I should see just the left side spin and and right front not move?
Thanks for the tip on diff lock. I did make sure to stop the spinning then press the pedal :)
/ JD MFWD on 2720 #4
The differential is "open" so yes it's quite normal to see only one side spinning. In reality you only have 3 wheel drive if you engage the diff lock pedal.
2002 48ft. T/A Flatbed Trailer (A61573)
2002 48ft. T/A...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
RoGator RG1300C (A63688)
RoGator RG1300C...
Snap-On Southern Thunder Edition 24-drawer tool box (A63689)
Snap-On Southern...
