PTO Alignment(?)
/ PTO Alignment(?) #1
genusCastor
East Texas prairie
see sig
A couple months ago I bought a used Yanmar-Cub Cadet SC2400, has a belly mower and end loader.
I've had the mower deck off a couple times now, and I'm pretty well certain there's only one orientation of the PTO that allows the shaft to slip on. I see one groove on the deck (female coupler) that is wider than the rest, and a groove between two splines on the tractor (male end) that seems to be filled in making a spline that's wider than the rest, and apparently those two (wide groove and wide spline) must be aligned. Any other orientation and the shaft will not slide all the way on.
I discovered this anomaly the first time I hooked the deck back up. Yesterday, even though I understood(?) the specific orientation, it was still difficult to get it lined up. Can't see that well up underneath there. Prolly took me close to an hr to get that :censored: thing back on. Seemed like it anyway, I dint time it.
Does this sound familiar? I did some innerweb research but can't find anything about this. I'm thinking I could dremel whatever it is between the two splines on the tractor shaft and then it would go on in any orientation. I can't imagine any functional reason it would be designed to be specifically oriented, it can't be blade timing ... can it?
- djb
/ PTO Alignment(?) #2
There HAVE been those times...... I get frustrated and go back in the house to have a cold drink of water. The ends of my PTO shaft will line up with the PTO stub on the tractor & implement in just about any way. As long as the splines align.
However - split the PTO shaft into two parts and there is only ONE way it goes back together. The actual shaft is square. One side of the square being longer than the other three sides. This forces you to reassemble the two halfs in one specific configuration.
BTW - I would not recommend doing any drastic grinding until somebody with more specific knowledge than I, can advise you. A couple of picture would certainly help.
/ PTO Alignment(?)
In all my years of being around farm equipment I've never seen a PTO like this before. But I've never worked with bottom mounted PTOs, they've been all rear PTOs.
On one site, if I was reading it correctly, the reason for a "keyed" PTO is so low RPM pieces of equipment can't be accidentally hooked up to a high RPM PTO. If that is all this frustrating design is for, I'll be grinding out the fill between splines on the male shaft so it will fit the female coupler in any orientation.
- djb
/ PTO Alignment(?) #4
When the PTO shaft splits into two parts (and normally telescopes when assembled) they need to be reassembled in one specific configuration ("in phase") so you don't get uneven speeds and wobble.
I'm not sure if this applies to OP's situation as it seems he's trying to put a PTO shaft on spline.
Picture would help.
/ PTO Alignment(?)
I'm not sure if this applies to OP's situation as it seems he trying to put a PTO shaft on spline.
Picture would help.
If phasing is the issue (as indicated by the drawing you posted) I wonder why phasing would be important on a bottom mounted PTO, but not a rear mounted PTO? I've never seen this on a rear PTO.
- djb
/ PTO Alignment(?)
Just noticed the square PTO shaft in the pic. The shaft on this mower deck is, indeed, splined, not square.
- djb
/ PTO Alignment(?) #7
- djb
...but are there universals joints (u-joints) that need to be connected "in phase"?
That is, are you connecting two sections of one (1) PTO shaft together?
I thought not. I thought you were connecting one yoke end of an assembled PTO shaft (hopefully "in phase" with itself) to tractor's spline?
Phasing is required between opposite ends of the PTO shaft (Shaft is required to be in phase with itself.)
No "phasing" is usually required between the pto shaft and the fixed tractor spline
Phasing is important on any PTO shaft (bottom or top) or drive line that has u-joints at each end.
/ PTO Alignment(?)
Maybe "PTO" is not even the correct terminology.
I'm referring to the shaft that drives the belly mower. It would look like pic below if totally removed, I am just dealing with separating the splined part of the shaft:
Sorry, and thanks for the responses.
- djb
/ PTO Alignment(?)
Ah, OK, I see what you're talking about...
What I'm doing is not like connecting an implement to rear PTO. I'm separating the shaft. It may be that the PTO shaft of, for example, my bush hog, does have a specific orientation to slip the thing together. It's been a long time since I've had one apart.
So this means I'm stuck with having to get that :censored: shaft together in a specific orientation.
Thanks again. I think I got my answer. User error. :laughing:
- djb
/ PTO Alignment(?) #10
For others following along:
Yes, the splined male/female parts of the 2 shafts that slide together at the 7" mark have to go together so that the two universal joints at the end are "in phase" with each other (as shown).
The yoked ends of this shaft can then mount to the tractor's or mower deck's pto shaft (spline) in any orientation. Just like with a rear PTO.
Yes, I'd bet the 2 sections of your Bushhog's pto shaft can only be slipped together in one orientation.
Yep, you're stuck cursing for an hour.
/ PTO Alignment(?) #12
- djb
Phasing is very important with ANY shaft with universal joints. Be it a baling machine, drive shaft on a truck, a PTO shaft....whatever....
Then we could get into the angling of those u-joints with some more physics.......
/ PTO Alignment(?) #13
geniousCastor, Once you get the orientation right, clean a spot on both parts and put a little dab of light colored paint on it. That'll save you a lot of aggravation. BTDT.
/ PTO Alignment(?) #14
- djb
Mark the two ends with a paint stick, then line up the marks next time you need to put it back together. That's what I done on mine which looks just like yours.
/ PTO Alignment(?)
Yessir, I might try that.
Another thing I learned after getting it together this time was that the bottom PTO shaft will turn if the PTO selector (Mid/Rear/Both) is set to Rear. I didn't know that and could not get the tractor shaft to turn. More frustration. :fiery: [ <- I like this guy :laughing: ]
I wonder if unbolting the yoke might be easier yet? But if so, someone would have suggested that already...?
- djb
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
1976 Athey Force Feed Loader (A61166)
1976 Athey Force...
2014 Chevrolet Caprice Sedan (A61569)
2014 Chevrolet...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 1HTMMAAL0DH414751 (A61165)
INOP/NON-RUNNING...
