Rotary cutter..what to expect?
/ Rotary cutter..what to expect?
I'm also in Upstate NY, and have done plenty of mowing in what looks like similar conditions to your pics. I've got a ck3510se, with a 2060 cutter. I banged the blades up pretty good last year, so they're far from sharp, but it's still doing a fine job this year cutting.
Like others have already said, your primary culprits are likely: going to fast, and not having the rear of the mower set high enough.
When mowing the really tall and thick stuff, I put it in low range, and keep it to a snails pace. It's faster to do it once slowly, than having to do it twice.
Here's a picture of my cutter from last year (when it was still shiny and new). This is the rear height setting I keep it at. I generally mow in 2 positions depending on which fields I'm mowing. Either the front end riding on the ground, for the lowest possible cut, or raised up about 3-4" for a 6-7" cut.
Thanks. That's actually lower than mine is currently set. I think the main issue here was a field that had a few years of no attention and weeds that were taking over. I went back over the top, flat area after a couple days and it looked great. Running a bit slower on the hill helped make a single pass look acceptable.
/ Rotary cutter..what to expect? #42
You can see initially we had some fairly high grass and weeds. Had to go slow and it did clump together some.
Now after a couple of mowings, I can mow it in medium and it doesn't clump. We are trying to mow it every two weeks.
Look great. The weeds here were (and some still are) 4'-6' tall!
/ Rotary cutter..what to expect? #44
It's a direct 2600:540 (or 4.814:1) engine-to-pto rpm ratio.
So in OP's picture where he's running at 2400 rpms, pto is turning 498 rpms instead of 540, basically 7.5% slower. Not a big whoop.
OP could just travel 7.5% (0.2 mph) slower than his usual 3 mph for the mower and pto to experience the equivalent torque (and equivalent blade revolutions per linear foot travel) as it would at 540 rpm .
Adjusting speed .2 mph can be tricky. :rolleyes:
on my brush hog i've not noticed any difference in 540E or 540 'full', usually run 2100-2200 rpm instead of 2600 (full 540).
ON my finish mower...yes, I notice and hear a big difference.
Just started using my flail (got a whole 90 min on it) so I'm still experimenting.
2019 DITCH WITCH FX25 PORTABLE VACUUM TRAILER (A59823)
2019 DITCH WITCH...
International 9200 (A61307)
International 9200...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
Towable Light Tower (A60352)
Towable Light...
Sellick S80 (A60462)
40 (A52708)
40 (A52708)
