Need to slow down PTO rpm
/ Need to slow down PTO rpm #21
The machine you linked is shearing more than cutting like a traditional saw. There's no sawdust. Draw a picture of what you're thinking to give us a better idea of what you want. Like others have said 60 RPM is quite low for a saw.
/ Need to slow down PTO rpm #22
a hydraulic shear would do the same and less dangerous - just use hydraulics/pump run the shear like a splitter
/ Need to slow down PTO rpm #24
There's quite a few of machines that do the same thing all over Europe... They burn small wood like that...
I don't see it as too dangerous, what I do see, is our society over here becoming afraid of just about EVERYTHING, and wanting some one (read government) to protect them at every minute, from themselves!!
I wouldn't be afraid to run that one bit!!
Build it if you want one and use a used car or truck transmission to slow the pto down!
SR
/ Need to slow down PTO rpm #25
Do a search on "Rebak", Many resourceful machines are made by real people that burn fuel wood .
For the smaller chunks , I would like to see the stoves that burn them.
I would use a truck differential (4:1) and throttle back the tractor engine rather than try for a 10:1 reduction.
Rebak wood fuel - Google Search
Don't let the "danger police" get in your head, they get in their cars every day and drive to the grocery. MUCH more risk there, but they just accept it as part of life. Just like rebak chunkers in Poland.
R-4 rębak MECHANIZM TNĄCY bez osłon POLSKA FABRYKA - YouTube
Thanks (everybody), i know about this 'Rębak', i have one like the one in the last movie. Problem is that my little Iseki is too light. But i see that it runs at incredible speed. So maybe i should have another look at it. Last time i tried it, it did not take more than 3 cm, anything bigger would shake the tractor so much, that it got stuck every time.
I will try to create some drawing about what i want to achieve, but it can take a few days. Busy with taking those little trees from the land :)
Thanks for all tips, directions, and thoughts. Appreciate it!
M.
/ Need to slow down PTO rpm #28
M.
Take a look on youtube for cordwood saws.
Vermont Woodsman Cordwood Saw
But like Kenny G suggested, a plain old table saw might be just right too.
/ Need to slow down PTO rpm #29
yours doesn't have the 3 speed PTO? My Bolens G152 did, I thought they were the same
Yes it has. Minimum speed = 472 rpm. Too much for what i had in mind. For the rest i truly love this machine :)
(1) Outrigger OTR IN445/50D710 Foam Filled Tire w/ Rim (A60463)
(1) Outrigger OTR...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
10' Container w/ Side Door (A60463)
10' Container w/...
2020 FORD F-600 SERVICE TRUCK (A60736)
2020 FORD F-600...
Iranch IRGC40 (A60463)
2024 Linx Trailer (A60462)
2024 Linx Trailer...
