Framing nail gun questions
/ Framing nail gun questions #21
The angle only affects how the nail feeds into the gun, it has nothing to do with how the nail holds. All the nails fire in straight.
What he said. Use the angle nail specified by the manufacturer to fit correctly into that manufacturer's feed mechanism. Sometimes you can get away with "close", ie 30* for 28*. I've used lots of different types and that harbor freight one should be ok for occasional use.
/ Framing nail gun questions #22
and while you are at it, be sure to get one of those soft, kink free air hoses. They will make life with a nail gun so much better!!!!
https://www.lowes.com/pd/Flexzilla-3...ose/1000746772
Harbor Freight has those air hoses as well and they are worth every penny! I have air hoses in rubber, PVC, and whatever these flex hoses are made of. These are so nice I've bought several and am replacing all my other hoses with them.
/ Framing nail gun questions #23
Hmm, one more thing. It’s more about the nails than the nail gun. Many building codes require full head nails. No nails with crescent shaped bits missing on the nail head.
/ Framing nail gun questions #24
And I think the building codes require the .131" diameter nails. Most commonly available are thinner than that.
/ Framing nail gun questions #25
I rarely use a framing nailer any more. On smaller jobs I'd rather grab my 1/4" impact, and use construction screws.
If you want to buy a nailer, HD has an option to register their models for a lifetime guarantee. Having had to throw away more than one nail gun because parts were no longer available, (thanks Bostich), knowing I'm not paying for a repair, or another gun, is a no brainer for me.
And, I like the way all the HD guns work, and feel.
/ Framing nail gun questions #26
1,000 3" nails is priced at $24.99 (less with coupons)
3deg 3 in. Galvanized Framing Nails 1, Pc
What would 1,000 3" screws cost? A one pound box of 3" drywall screws is usually over $10 and might contain 50-75.
/ Framing nail gun questions #27
When considering fasteners, and deciding between screws or nails, their cost should not be part of that process. These are what holds the building together and for each application, one is better then the other. For some projects, like a deck or wood fence, I will not use a single nail anywhere. For framing a the studs of a house, 3 1/4 inch or 3 1/2 inch nails are better, but most of the time I use 3 inch deck screws for the remodels that I do for clients and only bring out the framing gun when I'm doing a really big job.
/ Framing nail gun questions #28
Don't use drywall screws as a general purpose fastener - because it's crossectional area is small meaning it's shear strength is low and it's head is designed to snap off if to much force is applied to it. I've seen projects collapse because the head snapped off. Use structural screws instead. There are structural screws in the 1/4" range that are easy to drive, require no pilot hole and are stronger than a 1/2" lag screw.
The reason nails are used in framing instead of screws is because the cross sectional area is typically greater than screws, and they can be installed faster. However, with the new engineered screws, this is no longer the case for strength.
/ Framing nail gun questions #29
I use the term 'drywall' screws to mean whatever the larger black ones are. I have some 2 and 3" of those I use for certain framing things when boards need to be pulled together (warped or whatever), but I can't see paying the price for them by the thousand lot.
Looks like HF has abandoned the 28 degree nail item number I posted above as well as all other 28 degree nails and even my 28 degree gun, so I guess I'll have to try the 30s.
/ Framing nail gun questions #30
Yes, if you are only interested in price, by all means use nails. In fact, if you want cheap, hand nail. :D
Yes, construction screws are not inexpensive. However, they do a far superior job of pulling and holding things together. And, jobs where accuracy is important, can be done better with screws.
Plus, if you decide in the middle of the process, to go in a completely different direction, you can easily, and quickly take things apart.
As a bonus, installing screws is far safer.
They are worth the cost to me.
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2010 Deere 318D (A60462)
2010 Deere 318D...
2019 FORD F-250 (A60736)
2019 FORD F-250...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
2022 Kubota SVL97-2 (A60462)
2022 Kubota...
30ft Highway Trailer Co. Lowboy (A61307)
30ft Highway...
