Iseki tx1300f looking for engine repair manual
   / Iseki tx1300f looking for engine repair manual
he needs to examine why the injectors are putting out a stream instead of a mist first, though.. it could be bad injectors, or not enough pressure to them from a worn injector pump.. these parts are similar to an oil burner with either a worn nozzle, or low pressure to the nozzles, it puts out black smoke because the fuel is not being atomized properly..
The injector nozzles worn out any one know where I can get new ones
   / Iseki tx1300f looking for engine repair manual #22
Take a look at this video and see how your injector compares with the injector stream:
Full rack injection timing test - YouTube
There is a new injector tip in the injector shown by the person who gave up on it before me. It starts fine. Some would argue it isn't atomized properly. I would agree. Maybe the pump isn't putting up enough pressure. I wouldn't waste my time or money pursuing it though. Been there, learned not to. Just sharing my experience from the dozen or so of these I have worked on. Better atomization is better and correcting it may be enough to get you running a little longer. Cylinder leakage is more prevalent and will eventually catch up to you. More frequent oil changes are the only thing I know of to help combat this in lieu of re-ringing or boring/sleeving. With no hour meter and lack of discipline owners tend to neglect this item.
   / Iseki tx1300f looking for engine repair manual #23
I don't think the OP would call THAT a stream. at least it has some atomization to it.. Cylinder leakage can be diagnosed with a compression tester..
   / Iseki tx1300f looking for engine repair manual #24
   / Iseki tx1300f looking for engine repair manual #25
   / Iseki tx1300f looking for engine repair manual #26
send me a pm with your e-mail and I'll send you the manuals.
   / Iseki tx1300f looking for engine repair manual #27
Hi fxrs55 i dont suppose you have a detailed wiring diagram for a tx1500f and tx1510 only when i got my tx1500f tractor off of the "e" action site it had homemade wiring and i have got hold of a tx1510 wiring harness so i need to know the colours and the difference in colours that go to the same places
   / Iseki tx1300f looking for engine repair manual #28
This is what i have on the tx1300F (identical).
   / Iseki tx1300f looking for engine repair manual #30
here is one with more lights on the dash. turn signal pilot lamp and
parking lamp switch.
New/Unused Agrotk Tire Changer (A57454)
New/Unused Agrotk...
Heavy Duty 2 Post Car Lift (A57454)
Heavy Duty 2 Post...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
Killbros 260 Seed Conveyor (A56438)
Killbros 260 Seed...
Pull Behind Wood Splitter (A57453)
Pull Behind Wood...
