Fuel Filtter B2650
/ Fuel Filtter B2650 #1
coupman35
Gold Member
Northen Ontario
Now a L4060 had B2650
Small question is there a fuel shute off valve before the filter so you can turn off fuel when changing filter . Or do you have to train the tank.
/ Fuel Filtter B2650 #5
Manual says to not have fuel tank more than half full when removing fuel filter element to avoid excess leakage . Then to fill fuel tank after filter replaced and start and run engine for 30 seconds, then shut engine off, to bleed air from system.
/ Fuel Filtter B2650 #6
IIRC........I've changed the fuel filter with a full tank, as well as a 1/2 tank and it didn't seem to make a difference.... i.e. not much leakage either way.
/ Fuel Filtter B2650 #7
Cool! I'm going to do my 200 hour service today, and it will be the first time I changed out the fuel filter. my tank is already at half so I'm not going to worry about it anyway.
Set 4 - 12-16.5 tires on wheels for bobcat (A61567)
Set 4 - 12-16.5...
Westfield Conveyor (A61307)
Westfield Conveyor...
208315 (A58376)
208315 (A58376)
FORKLIFT (A56857)
FORKLIFT (A56857)
Electric Oven (A60352)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
