Diesel injector and pump
/ Diesel injector and pump #1
BertZegers
Gold Member
South-West Ontario
Kubota L2900, Zetor 8011, Kubota KX41Excavator, John Deere 4400 Combine, Case 1816C skidsteer
Something I am wondering about for some time.
I am wondering what the relationship is between injector opening pressure (pop pressure) and pump timing.
If the injector opening pressure gets lower, and the pump timing stays the same, would the diesel be injected earlier, and cause a timing problem?
YES. it does effect the timing..
I want to make a high pressure line to test Roosa Master injectors from a John Deere 329DH engine. Does some one know what the thread is on Roosa Master injectors?
The lines I have are metric, and go on just a few threads.
/ Diesel injector and pump #5
A fuel inj line from any JD 20-55 utility tractor should fit within thepumpguysc line recommendation. there were many tractors/implements powered by a JD 300 series engine.
/ Diesel injector and pump #6
Need to remember the length of the line is also a factor in the timing. All injector lines are the same length unless the fuel is metered at the injector.
2023 John Deere 6120M Tractor (A63109)
2023 John Deere...
2017 Dodge Ram Promaster 2500 Van (A63116)
2017 Dodge Ram...
Caterpillar 259D3 (A62180)
Caterpillar 259D3...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
(INOP)2020 CATERPILLAR 299D3 XE SKID STEER (A62129)
(INOP)2020...
UNUSED ATS CMR1280 ELE.CEMENT MIXER (A62131)
UNUSED ATS CMR1280...
