Added volt meter
/ Added volt meter #1
LS Tractor Owner
Super Member
Edgewood, NM
LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500
I hated not knowing what the battery status was at, so added a digital volt meter. Has a red, yellow, and green bar around the edge and a digital volt readout. Wired it into the fusebox supply, so a good reading.
/ Added volt meter #2
The lit circle is just fluff.... The actual numeric value is what is important.... Good job.... Don't know why all tractors have not gone to this.... The 14.2 volts indicate good charge voltage/system status voltage...
Dale
/ Added volt meter
Dale
What I really like about it is that when you just turn the key on, it will give the battery volts, then after starting, the charging volts. I agree that the manufacturers should have them standard.
/ Added volt meter #4
Nice install. I also think voltmeters should be standard on all vehicles. I cheaped-out on my L4060 by using a USB plug in adapter that also displays voltage. It's behind the operator, so less than ideal.
/ Added volt meter #5
Yep, good addition. As noted they should be factory. They certainly are cheap enough. I added one several years ago to my Kioti.
/ Added volt meter #6
That looks cool and serves the purpose. Nice!
I started out just wanting to add a clock to my dash and found the volt meter/clock from Trail Tech. Their stuff is geared more towards ATV's and off-road vehicles but made a good solution for what I wanted. You would think that a volt meter would be standard equipment on any tractor. IMG_20190630_164136.jpeg
/ Added volt meter
I started out just wanting to add a clock to my dash and found the volt meter/clock from Trail Tech. Their stuff is geared more towards ATV's and off-road vehicles but made a good solution for what I wanted. You would think that a volt meter would be standard equipment on any tractor. View attachment 611054
That's pretty cool, I didn't see any that had a clock when I was looking. (I also didn't have that requirement in my seach however)
/ Added volt meter #8
Has anybody added a digital tachometer to the tractor? I have a an older tractor and the Tach/hours meter does not work. Just wondering if anybody has any suggestions for a reliable unit.
Thanks
/ Added volt meter #9
Look up Trail Tech. They have all sorts of meters up to basically an entire instrument panel. Pricey, but they do take a beating in the off road rec vehicle world.
/ Added volt meter #10
I like the voltmeters.
Added a $3 voltmeter to my TC35 dash.
/ Added volt meter #11
Thanks
Tiny Tach makes a digital meter for diesel engines.
There is a pressure transducer which you clip to an injector line and it senses pulses.
You set the number of cylinders on the meter. $95
Diesel Tiny-Tach | Design Technology, Inc., Home of Tiny-Tach
Dave M7040
/ Added volt meter #13
I've been thinking about this for a while you may have just motivated me. but I want to add one to my solar powered gate and my dump trailer.
/ Added volt meter
The LED voltmeters draw miniscule amounts of power even if they are on all the time. They would be perfect for that application.
/ Added volt meter #15
I have a number of these volt meters on various machines.
One was a Toro Zero Turn. I wired it on all the time. In a week my battery was dead.
A little current 24/7 adds up.
Dave M7040
/ Added volt meter #16
Today's automotive alternators are very reliable and rarely fail. I would rather mind engine coolant temperature and engine oil pressure. For me, charging voltage is always OK unless the alternator lamp glows after engine start. This was the case with my used M-F when I purchased it. My DVOM at the battery terminals engine running showed lower than normal voltage (14.2 is typical alternator charging voltage for a flooded SLA battery. AGMs charge at a higher voltage, ~14.7 VDC). I disassembled the alternator only to find the copper slip rings almost worn away. A rebuilt alternator was installed and all is now well. Remember too, a diesel engine will run for some time in a total loss situation. I could run most of the day with my crippled alternator.
/ Added volt meter #17
the gate meter would be on all the time, but the dump trailer I was thinking maybe a momentary switch so I can confirm the batteries state of charge and also that it has a good connection when I connect it to the truck
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2022 John Deere 317G Track Loader (A63109)
2022 John Deere...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
Chain Link Fencing (A61166)
Chain Link Fencing...
UNUSED JOHN DEERE STRIP-TILL WHEEL ASSIST (A62131)
UNUSED JOHN DEERE...
