Flail Mower Titan Flail mower
/ Titan Flail mower #101
Maybe a bit off topic but, I damaged the plastic PTO shaft plastic safety cover chain attachment loop when I lifted the mower with the anti rotation chains attached and tore the tractor end chain off. Has anyone found a reliable repair for reattaching the chain to the plastic safety cover thingamajig? I'm always concerned regarding safety and those PTO shaft covers provide safety when they are properly attached.
A hose clamp. I used one to strap a chain to mine. The flimsy plastic loop on mine broke when I hung the shaft from that chain.
I hear its intentionally flimsy. That way the chain isnt whipping around if the shield jams & starts spinning.
/ Titan Flail mower #102
The plastic covers are specific to the shaft manufacturer. But sometimes you can find them. AgriSupply has a lot of PTO shaft parts.
/ Titan Flail mower #103
I took the covers off mine...makes greasing a lot easier. How the driveshaft could ever be a safety issue is beyond me. Who leans over a spinning driveshaft?
Ran my 72" Titan last night for 3 hours and today for 3 more. The welds I made last year are holding up, everything *seems* to be OK. I'm moving through some extremely dense and tall 4+ feet grass. Gotta watch out for fawns and baby birds hiding in the grass.
/ Titan Flail mower #104
Do not run over Bambi with your flail!
/ Titan Flail mower #105
My chain broke off the same way and I left it off the last time, but planned to use a hose clamp as well.
/ Titan Flail mower #106
The idea of an exposed spinning shaft just makes me nervous. I would likely never put myself in danger by engaging the PTO then getting off the tractor and deliberately leaning over the exposed spinning shaft while wearing a long necktie. But, there are those who might be less cognizant of the spinning machinery and could get hurt.
Agreed regarding greasing the PTO shaft.
/ Titan Flail mower #107
I don't have a picture, but I have a different friend with some scrap metal and he welded some braces on and gave me a 5 minute lesson in welding to boot. After welding we pried on it a little with another scrap piece and I think it will be stronger than before. Strong enough? Only time will tell.
:thumbsup: . . . practice, practice, practice . . . you will only get better and watch your puddle :)
/ Titan Flail mower #108
Boy ain't that the truth . . . 2 days ago I'm mowing some pasture with a bit of forest, sure enough there was Bambi.
/ Titan Flail mower #109
I have deer and foxes living in the forest/thicket behind my orchard. I see them from time to time but they are shy and keep their distance. I would sure hate to harm any of them. The fox came through the back yard near the house last year. He has a beautiful red tail. During winter, I would put out roasted chicken carcasses. He would carry them back to his lair. The deer were chewing on my newly planted fruit trees a year ago. Now, they are no longer interested since I began feeding them corn...smart deer.
/ Titan Flail mower #110
I hate to say it but exactly that happened to me two years ago. Just couldn稚 see it in the tall grass.
/ Titan Flail mower #112
That would make me sick. When I'm in tall grass and need to see the ground ahead better, I stand up to better judge what's ahead.
In this case I was mowing at the edge of a public drinking water reservoir. I was going very slow, but my focus was keeping the mower and wheels right at the edge of the water without dropping in which would have been a huge problem. The grass was extremely tall. I thought I ran over a log which frequently drift in to the shoreline when the water gets high. It was a quick, if not brutal death for the poor thing. I did feel pretty terrible about it, but there really was nothing I could have done. I've had them pop up nearly right in front of me and wobble away while I wait, but this one didn't. I dragged what was left off into the woodline. Anyway, I always try to be extra cautious.
/ Titan Flail mower #113
Troverman,
Please don't misconstrue my comments...you did nothing wrong...it was an accident. I am not judging you. I'll bet your a nice fellow...I might like to have a beer with you one day...you're buyin'.
/ Titan Flail mower #114
Yeah, no worries def38. Appreciate your comment.
As for my Titan mower, I ran it for another 8 hours yesterday. Unfortunately, one of the flail knife supports on the drum broke off, leaving the knife supported only on one side. It still mows and doesn't vibrate, but I'm not sure how to fix this. Can you buy the supports separately? I'm thinking about trying to weld the bolt head to what's left of the support for now. What do you guys think?
/ Titan Flail mower #115
Hello Troverman,
my first reaction was YYYYYEEESHHHH!!!!!!!!, UGH.
That is damage that a peanuts happy dance will not solve for sure.
NOW to the problem at hand; the best thing to do is to remove the 2 hammer knives above the broken one in the
image you were so kind in uploading. Removing them will prevent the possible bearing damage from an out of balance
flail mower rotor.
You could have a mounting lug made by a welding shop but the chance of heliarc welding it on the flail mower body could
fry the bearings and weld the inner bearing races to the stub shaft of the flail mower rotor is very high.
Gas welding would be the preferred method to do this after grinding the old weld off but it will require patience and multiple layers of weld to strengthen the
weldment of the new welding lug.
Getting the original lug weight should be as near as possible to the original with the steel thickness, lug height and its width with the mounting hole drilled in the lug.
If the welding shop has a rosebud torch the welder could heat up the rotor and the mounting lug and create a better weld with less
potential damage to the bearings as long as the ground is welded to the flail mower rotor close to the broken mounting station.
The ground should be welded in line to with the second mounting lug in the image you provided after the rotor is heated with
the rosebud torch.
I wish I could be more help but ideally the best way to fix it is to remove the flail mower rotor and weld the new lug in place after the section is heated with a rosebud torch then balance it using a high speed balancer.
Removing the 2 hammer knives closest to the broken mounting station will be the better option as this section of flail mower rotor will no longer
be in play and affect the balance of the flail mower rotor. I am assuming the mounting stations are 120 degrees apart and the removal of the 2
hammer knives will cancel the effect being an imbalanced state that they create when the flail mower is running at 2,200 RPM+-
You will have to mow a bit more but the repair job is really a winter/no mowing season job to do it well.
You could do what Iron Horse did with his mule in Australia- He essentially hung a york rake under the mule so that he could avoid having any potential impact damage to the mower stopped before it could enter the mower body.
Having a steel rake made up and mounted in front on the engine frame -if your mule has an engine cradle would be the best way to do this as it would be long enough to almost reach the ground using the chain as a measure to hook to shackles on both sides and you would still be able to lift it up and chain it vertically in place to keep it out of the way.
I wish I could be more help.
/ Titan Flail mower #116
Hello Troverman,
Hi Leon, my dear friend, nice to see you here again, best wishes to you.
Hi Troverman, this is the CAD drawing for that hammer bracket, the size in the drawing is millimeter.QQ截图20190627220918.jpg
Remove the old welding material, then weld this bracket again.
/ Titan Flail mower #117
Thanks Leonz.
I had one of those mounting stations break completely off on both sides last year, taking the hammer knife with it. Fortunately, I was able to recover all the parts, and a welding shop welded it back on in-situ. No problems with that one since.
This morning I decided to trailer the whole thing back to my workplace, where we have a small gas MIG welder. One of the guys who's better at welding than me is going to grind off the broken mounting station and weld a new piece in that is the same basic size and thickeness, and hopefully I'll be back in business later this afternoon.
I honestly look at these Titan flail mowers as throw-away items. If welding somehow damages the bearings or something else, I couldn't care less. I wanted this mower to last at least the first cutting of my two-cutting 2019 season; we'll see if this repair can limp it along until I drop another $1600.
I see many flail mowers are designed like this with welded cutting stations. Bad design, in my opinion. My Vrismo uses a rod-through-drum design with a triangular hanger and loop system. In this case, the flail knife, the loop, or the hanger can all fail before any damage is ever done to the rod or drum, and they are all easily replaced without welding...replace in the field.
The Titan does cut OK when it's working. My biggest complaints are the top-link uprights are not strong enough and frequently break, the roller is too small and has the most terrible open bearing design which clogs with grass and stops rolling almost immediately, and finally, the method of mounting the flails. It's cheap to buy, and that's what it has going for it.
/ Titan Flail mower #118
Hi Troverman, this is the CAD drawing for that hammer bracket, the size in the drawing is millimeter.View attachment 610570
Very helpful - thanks! I will use this as a template.
/ Titan Flail mower #119
So I repaired it and went a different route to do it. Since the lower portion of the mounting station still existed, I ground the area clean and welded the nut and bolt to it, in their proper position. The flail knife pivots on the bolt, so that is not affected. I built the area up all around it so it is surrounded by weld. The mower runs and I'll be heading out shortly to mow for 7 hours. I suspect it will be fine. Thanks for all your help.
/ Titan Flail mower #120
Hope it works out well for you.
2011 Cadillac Escalade 4x4 Ext. Cab Pickup Truck (A61573)
2011 Cadillac...
2014 GMC SIERRA 1500 (A62613)
2014 GMC SIERRA...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
WHITE 2-60 TRACTOR (A63291)
WHITE 2-60 TRACTOR...
159118 (A60430)
159118 (A60430)
