GC 2410 Suction filter threads
   / GC 2410 Suction filter threads #1
DaleAP
Member
Averill Park NY
Massey Ferguson GC2410
Anyone know what the thread size and type is on the side filter for the GC transmission? I cross threaded and need to run a chase through.
Thanks
Dale
   / GC 2410 Suction filter threads #2
Sorry, no... but I do know it's extremely easy to get that thing cross-threaded!
   / GC 2410 Suction filter threads #3
There is a way to figure it out manually using thread count and a tape measure. I have never tried it but searching how to on this should help.
   / GC 2410 Suction filter threads #4
Being it's possibly a meric tractor, have metric tools?.... End wrench opening will give you diameter, generally with metrics there is only 2 variation of threads per MM per given diameter, one is fine thread one is coarse thread....
And then there is these....
Vermont American Screw Pitch Gauge, Metric 21938 | Zoro.com
Dale
   / GC 2410 Suction filter threads #5
Thanks
Dale
Sorry, searched my MF Service Manual, and my MF Parts Catalog, and the online MF Parts lookup website, and I could not find the information you are looking for.
I would try calling your MF Dealer Parts/Service and maybe they would be able to provide you with the type of threads for the Hydraulic Suction Filter.
Maybe at the last resort, Jack's Small Engine has the "Suction Pipe" part # 4265209(91 for $84, ouch...
Massey Ferguson 426529M91 PIPE - Jacks Small Engines
KC
   / GC 2410 Suction filter threads #6
Go to Fastenal or other hardware store with a good nut and bolt selection. Go grab some appropriate sizes metric nuts. Start trying to screw them on. Once you get to the one that fits, you know what you got.
I had to get a new suction filter as I messed up the mesh taking it out, or it was like that from the factory, and it's a fairly good sized hole. I want to say it's going to be around M16-M20 x 1.5.
   / GC 2410 Suction filter threads #7
I know the outer nut of the filter is 22mm (7/8" in std) if that helps. I can't recall if it was a course or fine, or what the thread count was. I would possibly contact the service dept of the nearest dealer, they should know or be able to look it up.
   / GC 2410 Suction filter threads #8
I feared I had done that so just cranked in in until the seal seated and said to myself that's the last time I clean that out.
   / GC 2410 Suction filter threads #9
If you have a small machine shop nearby, they could easily measure your screen and tell you size, and thread it its.
I'm not sure where you buy and individual chaser that size, without having to buy a whole set. Perhaps you can get the machine shop will help you out there too?
If you find a chasers that big for sale individually, please post a link.
   / GC 2410 Suction filter threads #10
Just a shot in the dark here, but might that be pipe thread? Grab a 3/4 and a 1 coupling at the hardware store, or just take your screen into the store and try the fittings out by hand. A few turns will tell the tale.
J and L Cargo Express Shadowmaster Enclosed Trailer (A52128)
J and L Cargo...
UNUSED CFG Industrial MX50R Mini Excavator (A47384)
UNUSED CFG...
2014 International Durastar 4300 Terex BT3063 30,000lb 63ft Crane Truck (A50323)
2014 International...
2014 Chevrolet Tahoe (A50324)
2014 Chevrolet...
2002 International 9200i Truck (A52128)
2002 International...
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
