Gear shift lock into gear
/ Gear shift lock into gear #1
tbarrick
Member
shibaura 1540
Just bought a used kioti lb 18914. Used it for about 90 minutes and gear selector locked into 3rd and wont come out. Shuttle shift works, low/high works but cant get out of 3rd......got the shift stick to move out of the H pattern 3 position but would not disengage from 3rd gear.... Is this going to be a split the tractor to work on transmission proposition?
/ Gear shift lock into gear #2
I have no experience with your particular model, but do have considerable transmission experience, and can say (for near certainty) this is not a "split the tractor" problem. It is (almost) for sure a shifter - linkage problem. Typically the shifter reaches the 'neutral gate' before the forks actually fully disengage the 'active' gear (this instance 3rd gear). There is a safety feature in the transmission that prevents more than one gear (at a time) being selected, so why the shifter "thinks" the transmission is in neutral, it is in fact still in 3rd.
It can be caused by wear, or linkage coming loose, or something jamming the linkage.
It was not clear (to me) if (1) you cannot get the "shift stick" to move to neutral, or (2) it does move into neutral, but the transmission remains in 3rd.
If (1), probably something is jamming the shifter or linkage. This could well be something inside the transmission cover plate, and be a bit complicated to explain, and to perform for the first time.
If (2), probably something is worn / bent / or needs adjusting.
If you can still move the "shift stick" (into the neutral gate), try "re-engaging" 3rd gear with the stick, then straight from 3rd, through neutral, and into 4th.
If that works, something is very likely worn (or loose). If caused by wear, you can teach yourself to "work around" the wear; - pull (push) the shift stick well into the neutral gate BEFORE pushing it sideways to go into the next gear (1st or 2nd, in this instance)
Good Luck! please keep us posted on what you find.
Thanks for the encouragement. The shifter was not able to even go into neutral but I did manage to get it...somehow....into the neutral/other half of the H pattern but now it is locked into that position even though the transmission is still in 3rd gear.....if that makes more sense to you. This makes me think your # 1 explanation is the answer. I am not able to really tear into it until after Sunday as I need it to stay functional until after my son's wedding that I am hosting onsite and have other pressing issues.
Took the shifter lever cover off and this is what i see..... kioti trans.jpg
Have tried to pry the left traveler up (forward) even removed the detent spring and ball bearing at top of picture....to no avail. Cannot get it to come out of 3rd.
Meet Google Drive – One place for all your files
Here is the link to the picture if it won't show up.
/ Gear shift lock into gear #5
Try moving the 1-2 shaft/fork (right one) forward/backward, and see if that frees up the 3-4 shaft. You should start with removing both detent springs and balls. There is a "blocking" pin that rides in grooves in the shafts (opposite ends from the detents). I am guessing that there is wear in that groove/pin and/or the detent grooves that is allowing both shift shafts to be slightly out of neutral at the same time, and that has jammed the 3-4 shaft in 3rd gear.
If 'jiggling' the 1-2 shaft doesn't help, take very careful notice if either/both shafts seem to be frozen in place. The forks are held tightly to the shafts, but there will be a slight 'looseness' between the forks and the grooves they ride in (typically 1/16" +/-). This "looseness" should be enough to determine if the problem is in the shafts, or in the synchronizers/sliding gear (looks like yours has the sliding gears - but it is kind of dark in your picture).
With both detents removed you should be able to move both shafts front to rear, and rotate - A VERY small amount, but enough to 'feel' that the shaft itself is not frozen. You should also be able to push (front to rear) on the gears ( synchronizers) that the forks ride in, and verify that they move freely (again, a very small amount, but enough to know that it will slide on the splines).
Without being there 'hands on' it is very difficult for me to 'articulate' what to look for, and how to check it. Just looking at the picture, I cannot visualize how you got the shifter out of 3rd gear to start with; there must be some 'movement' of the shafts???
Please keep us posted on what you find.
I am able to move the left (3/4) fork forward about 3/8 to 1/2 and inch. I will try the 1-2 fork next....
/ Gear shift lock into gear #7
Maybe one of those locating split pins has sheared and allowed the selector to move along on the shaft.
I took the next layer off and removed the "forks" and both of them slide independently. When one goes up or down the other is locked into position. The "balls" that they lock onto in the 2nd picture do not move freely. the bottom one jiggles for and aft but the front/top one does not. The left one is the 1/2 (right side slider) and the right/back is the 3/4 slider.20190627_112822.jpg20190627_112830.jpg
put it back together and got it out of 3rd.....used it for about 20 minutes and put it in 3 for a bit and it was locked again....eventually got it out and used 1 and 2 for the next hour with no issues. Got it into 4th a couple times and would grind and not be in gear and took a couple tries and then would lock into gear.....what do you think I should do...sell it? scrap it? Is this an easy fix?
/ Gear shift lock into gear #10
Just a guess, is it possible the 3/4 shift fork is bent? Engaging 3rd hard and not quite engaging 4th?
/ Gear shift lock into gear #11
"I took the next layer off and removed the "forks" and both of them slide independently. When one goes up or down the other is locked into position. The "balls" that they lock onto in the 2nd picture do not move freely. the bottom one jiggles for and aft but the front/top one does not"
This seems like a very unusual transmission! Usually the cluster gear is on bottom, and the sliding gears on top. I may not be looking at it correctly, but it seems like the forks go down into the trans oil, and the sliding gears are completely under the oil. I think the "balls" you mention are the upper most part of the forks (the rest of the forks are below the oil and are not visible)
It sounds like you are saying that in the "layer" you removed, the two shafts do go back and forth freely, and that the lock out function is working also.
The "balls" (forks) should slide freely on the shaft; and it sounds like you are saying that at least one of them (forks) is not. If it were me, I would begin by draining the oil so that I could see into the bottom of the transmission. It should be relatively easy to determine if the fork is 'bound' to the shaft, or if it is the sliding gear that is binding on the splines.
/ Gear shift lock into gear #12
It sounds like a mechanical issue with the gear selector on your Kioti LB 18914. If you're unable to shift out of 3rd gear, you may need to consult a certified mechanic or dealership to diagnose the problem and determine if disassembling the tractor is necessary to fix the issue. It's possible that there could be a problem with the shift mechanism or linkage, or an issue with the internal components of the transmission.
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
PALLET OF HEAVYEQUIPMENT PUMP PARTS (A68842)
PALLET OF...
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
2026 GIYI FB77 Feller Buncher Skid Steer Attachment (A66734)
2026 GIYI FB77...
219065 (A65056)
219065 (A65056)
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
