My M7060 purchase and usage thread
/ My M7060 purchase and usage thread
I was ridiculed for buying a M7060HD-12 to use for tree work.
You can稚 load a log truck or Pulpwood truck or your chip truck with a Farm tractor.
View attachment 598358View attachment 598359
Ok.
It also does pretty good when loading pine tops into the Chipper.
I use mine for tree work also. Grapple loads logs onto dump trailer and the Woodland Mills 8" chipper handles all the smaller stuff. If there are any stumps to grind I use my PTO Stump grinder. I can haul everything mentioned at one time in a 16' gooseneck dump trailer. Unload at site, do job and haul off chips, logs etc and then return and load up and go. I may be a bit slower than a larger crew with more equipment but with my setup 2 of us can do pretty much anything that a large crew with several trucks trailer and pieces of equipment can do. My unique setup is very versatile and every customer has been pleased and impressed. This setup would not be idea in a more urban environment but most of my work is suburban or rural.
/ My M7060 purchase and usage thread #182
Has anyone adjusted the valves yet? I just did my L4300 and need to do the 7060 also, the WSM is in the mail, just wondering if anyone did it yet.
/ My M7060 purchase and usage thread #183
I’m near 800 hours on my 5240 and will need to adjust the valves. I’ve done them on other diesel engines and it is pretty straight forward but I’m going to get a service manual anyway.
/ My M7060 purchase and usage thread #184
I’m only at 250 hours on mine, so no valve adjustment. I would imagine it would be simple to figure out once you get the WSM. :)
/ My M7060 purchase and usage thread #185
For those who have trouble reconnecting the hydraulic line, have a look at a "multi coupling plate". I ave seen 2,4,and 6 gang plates and used the 4 gang. WAAAAAY better than individual lines AND you just DON'T have "stubborn connector problems". The bonus is it is a lot faster too.
See stucchiusa.com and go to multi coupling plate.
They are common on the larger JD MF NH Class and Fendt tractors.
But be careful when hooking up under pressure with those units. I blew a seal on the unit. Dropped the grapple already still under pressure, i was in a hurry. When I hooked it up again, I blew the seal. The day was done.$27 later, I figured that tiny seal doesn't even fit on my pinky. To replace it, takes some patience but is doable. it was on the grapple side, easy to remove so I could work on it on the work bench.
Ever since, I release the pressure religiously, whether it's the grapple or the whole loader that I'm taking off.
/ My M7060 purchase and usage thread #186
lpigott, Im looking at the same machine you have right now and was wondering about your Regens and such.
What frequency are you experiencing with the DPF regens? Any issues with all that ?
TIA
/ My M7060 purchase and usage thread #187
TIA
Once every 4-6 hrs if running under 1600 rpm.
If you run it higher, I’ve seen 12-14 hrs.
/ My M7060 purchase and usage thread #188
Good response
Wayyyy better than the generic "no problems, never notice it".
/ My M7060 purchase and usage thread #190
/ My M7060 purchase and usage thread #191
It’s not been an issue for us.
Nor for me. I couldn't put a figure on how many hours between regens; I'd have to keep a logbook in the tractor and write down the hours when I see the light come on in the dash and I'm not about to do that. Problem is, I don't always notice the light coming on when working the tractor. There's times when I notice the light is on and then it goes off a minute or so later so I know, since regens generally take 10-15 minutes, that the light must have been on for a few minutes before I saw it.
The tractor now has ~ 320 hours on it. The only regeneration process in that time that I really noticed was just recently. I was removing the front end loader preparatory to mowing, moving equipment around, and then hooking up the mower. It was cold, and the Kubota had been idling for an hour+, when I noticed the regen light in the dash was blinking as was the light telling me I had to increase the rpms so the regen process could take place. I ran the rpms up to 2000 rpm and let the tractor run at that engine speed while I washed the windows. By the time I was done with the windows (inside and out) the regen light was out.
/ My M7060 purchase and usage thread #192
TIA
I actually do keep a log, I'm at 800 hours and never missed a regen. I like the 7060 very much but do find the regen to be annoying. I use the tractor for about 45 minutes to an hour a day through the cold winter to clean my barn, and find in the winter it regens at about 14 hrs. The issue is that when I know a regen is getting close, I don't like doing things that require delicate clutch work like loading round bales onto a truck or bale wrapper. I cant just push the throttle up to 2000 rpm and slip the **** out of the clutch, that hurts my soul, and I hate explaining to an old school associate that my fancy tractor needs to wipe its *** for 10 minutes before I get her rolling again. The regen is no issue at all as people always state while mowing, raking, baling or any other long duration activity, but it is annoying when doing tight work.
Just my opinion... I do love the tractor otherwise.
/ My M7060 purchase and usage thread #193
Thanks fellas for the first-hand feedback. Ive ruminated over this purchase for a few years and all things considered think its the right one for me. I readily admit the whole Tier-4 is a huge pain in the arse, but I still like the fact there is no DEF on this model and after reading many years of owners experiences, the M7060 has been a pretty good machine overall (yeah I know there are nit-picks, but every tractor out there has something).
Ordered it yesterday, HDC12, cast rears with wheel weights, radials, radio, air seat and 3 remotes. Summer is cranking up here in ole Tejas and hopefully it will be a lot more bearable with that cab and cold A/C.
/ My M7060 purchase and usage thread #194
Sounds to me like you are a good candidate for the creeper gear option. It would allow you to keep the revs up yet the speed down.
/ My M7060 purchase and usage thread #195
The A/C is nice. But for me the real prize is being enclosed in that cab. With the a/c on and the fan blowing and pressurizing the interior of the cab those huge clouds of dust I used to have to endure (mowing desert!) and breathe are no longer a problem. Used to have to get in the shower to wash off all the dirt immediately after mowing - and blowing my nose produced black mud for the next day or so. Nor are all those biting/stinging insects a problem any longer! Makes me smile when I see all the bugs on the windows while I sit comfortably inside.
/ My M7060 purchase and usage thread #196
Congrats! You have a very nice tractor headed your way:thumbsup:
/ My M7060 purchase and usage thread #197
Congrats. Looking forward to positive reports with use.
/ My M7060 purchase and usage thread #198
No, the problem is changing direction frequently, in close quarters, especially with a heavy load on the loader. No clutch is going to be happy for long operating at 2000 RPM in those conditions. It's a great machine, I love it, but the regens can be inconvenient.
/ My M7060 purchase and usage thread #199
I thought that with Kubota's left hand reverser or "shuttle" there was no actual clutch or clutch wear components like you would have on a conventional "manual" transmission, and that it was all handled hydraulically? I believe I read that here on TBN. I fully understand that clutch wear concern and prefer no (set) throttle other than foot throttle for loader work, especially loading a wagon or truck.
I'll be curious to see if someone (Messicks?) chimes in with the Hyd. shuttle's actual operation.
/ My M7060 purchase and usage thread #200
If it's a GST, it has both a regular dry clutch and a wet clutch.
The wet clutch is controlled by the transmission ecu and works with the gearshifter or the shuttle, but it can be jerky, not what you want for tight work in a barn.
Aaron Z
PALLET OF MISC FILTERS & ECT (A63291)
PALLET OF MISC...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
60in Bucket Skid Steer Attachment (A61572)
60in Bucket Skid...
2022 CASE TV450B SKID STEER (A64279)
2022 CASE TV450B...
