NX - lost travel functions
/ NX - lost travel functions #1
DieselBound
Elite Member
Arlington, WA
Kubota B7800; Kioti NX5510HC
I'd been struggling with this for a while. My forward travel pedal on my NX5510, since day 1, had this very slight sticking point where when letting up on it it would delay ever so slightly and kind of make a light popping noise, like it was momentarily hanging up and then letting go. I had thought that it was just tight tolerances and that it would eventually free up. Fast forward to more recent times and it got to the point where it was hanging up, not fully releasing; also a pain as I'd go to stomp on the reverse travel pedal and get the stupid "CAL" light; I'd have to nudge up under the forward travel pedal to get it back to it's full neutral position.
I poked around at it a bit but wasn't able to really figure out what was going on. It looked like a mess to deal with so I just put it off. When I had the tractor at the dealer's (leaking rear axle casings- replaced under warranty) I mentioned this to them and they said that they messed with it (though I didn't really expect them to do so- just making a note). With the tractor back I found it to be better, but once it was used for a while, thermal change?, it would once again start sticking. So, at the 400hr service I decided to tackle it. Turns out that the gap in one of the two fork channels that the rear of the travel pedal "turnbuckle" goes in to was too tight. I pried it open a bit and no more sticking! Lubed everything up and felt that I'd beat this thing. And then...
After a little while I found that, once again, the forward travel pedal wasn't properly returning to its neutral position. The pedal, however, wasn't hanging up (so THAT issue is resolved!). It's more like the return springs are weak. I continued to mow figuring that I'd look at it, again, later on. And then I stomp down on the forward travel pedal and I hear a popping sound and the pedal goes limp! Forward travel wasn't possible so I figured I could pull up on the pedal and use reverse to get myself back home. Nothing doing! NO TRAVEL WHATSOEVER! Grr! Got my wife to steer the Kioti while I towed it (in reverse) with the B7800 (almost 1/4 mile). So...
I KNOW that one of the return springs toward the back shaft is dislodged; no idea yet how I can get it reseated. But, not sure on the bits that work with the potentiometer, why, when pulling up on the forward travel, I couldn't get reverse travel.
Page 6-31 of the service manual has the diagram of all the bits. Item #28 is what I messed with (gapped it open a tad more). Item #31 is the spring that is no longer tensioned: hoping that the #17 bolt is the pin/stop and that I can back that bolt out, wind up the spring and then thread the bolt back in (to hold).
I think that shortening up the travel rod ("turnbuckle") should help the pedal to return to the neutral position: manual says it's supposed to be 171mm; wonder if the dealer messed with this? (I have not adjusted it.) I'm concerned, though, that the springs are still weak, and with the one popping out/off I don't know that it won't do this again.
Has anyone else had issues with weak travel pedals?
Broken spring:
Looks like this was defective to start with as the break is dark like it's been fractured for a while and then finally gave up.
Getting at this thing is a HUGE pain. Have to disconnect connecting rod and the pedals and drop the assembly down (where it's still harder than heck to work on). Not sure how I'm going to get it all back together...
/ NX - lost travel functions #3
Broken spring:
I haven't had a pedal return spring fail on me, but I have had dibris limit forward and reverse pedal travel several times. I did break the spring on the steering colume last year, an easy fix.
/ NX - lost travel functions #4
Thanks for the info, and for giving us the benefit of your experience. Hope it doesn't happen to me, but if it does, I know where to look!
Managed to get everything back together. I wasn't able to figure out how to disconnect the wire harness for the potentiometers in which case I removed them as attached to their mounting bracket from the pedal bracket: doing so meant having to reattach tiny linkage bits (to the potentiometer); good luck if you have fat hands- ain't going to be able to do it! (pray that none of those retainer clips ever pops out!)
A few things I found troubling (well, besides the broken spring!):
1) The nut for the potentiometer linkage for reverse was loose (that linkage piece was bent, likely due to being loose);
2) Bushings that go into the pedal linkage sleeves are multi-piece, two of them, and they shift around: I thought that I as missing one (forward pedal), only to find that it was slid over toward the other side- this could provide for slight racking along the mounting shaft; I pulled it back toward the outer edge (will it stay there?);
3) The return springs wore grooves in the shoulder (outer edges) of the pedal arms (have to zoom in); I can only wonder whether the springs are binding into these groves (pinching between the arm and the bracket):
Here's the exploded diagram of all of this:
Ford 7000 (A64127)
Ford 7000 (A64127)
2019 KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A65053)
2019 KUBOTA KX71-3...
Kubota Diesel Utility Tractor (A62679)
Kubota Diesel...
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
2016 FORD TRANSIT T350 EL SRW HI ROOF VAN (A59914)
2016 FORD TRANSIT...
Morooka MST 2200V Tracked Truck (A62679)
Morooka MST 2200V...
