Tires - Replace?
/ Tires - Replace? #1
B2150hsd
Kubota B2150hst
I realize this maybe a dumb question but rear tires are expensive and I read that people run tires until cords are showing and I do not see any. The tires are the originals made in 1995 and are on a 650 hour B2150hst 4wd. They are tubed and have a liquid ballast. If the tractor was used on level ground I'd just run them til they got worse. However, I rotary cut steep slopes on my property and in some areas their is not a flat exit or landing point at the bottom of the slope. Just a wall of trees on an even steeper grade. What do you guys think?
/ Tires - Replace? #2
I 100% agree your situation call's for new rubber. You can sell those for 30% of what new one's cost.
/ Tires - Replace? #3
If you need them and they must be dependable, replace them. If you were just puttering with it, maybe flip a coin.
You could coat them with a product called "tire paint" that would fill those cracks to a degree and make the tires look a whole lot better. Keep in barn when not in use and keep the pressure up and they could go for years. They would also be subject to something going wrong--flat--when you least expect it. Maybe, maybe not.
/ Tires - Replace? #4
They’re a low pressure low speed tire. Sudden catastrophic failure is highly unlikely. I’d keep using them.
/ Tires - Replace? #5
It seems like you're more concerned with traction than tire failure. Are you experiencing more slippage than in the past?
If so I would replace them. You will need to eventually, and the next set will most likely last another 14 years.
/ Tires - Replace? #6
Its been 24 years.
/ Tires - Replace? #7
It's time the old girl gets some new shoes.
/ Tires - Replace? #9
If it is a concern to you - replace them. From what I can see - they have MANY more years of good use. I really doubt that new tires will provide that much more noticeable grip. The inner tubes will almost totally eliminate catastrophic failure.
My tires on my first tractor had that much tread remaining after 27 years. They had NO cracks. Keep your tractor OUT OF THE SUN when not in use.
/ Tires - Replace? #11
those tire sidewalls are probably 3/4" thick or more.... low pressure, low speed.... I wouldn't
waste money, probably good for 20 years more
/ Tires - Replace? #12
I'd run them until they started leaking or ran out of traction if you were on flat ground. The penalty for failure is low & recovery options aren't hard.
However if you are on reasonably steep slopes the penalty for failure & recovery options get a lot more ugly. If you loose a tire in a bad spot you could roll the machine.
I'd replace the tires if I were on slopes & my tires were rotting a lot.
/ Tires - Replace?
Wow, I like all the different responses. I should have made a poll for this thread. To clarify somethings:
- They are ~25 years old
- Traction is not a problem. The lugs are still large. Only 650 hours and all on grass and dirt
- Liquid ballast at about 75%
- They are currently tubed with the originals. Not sure how long they hold
- They do not leak. Rarely have to air them up.
- I try to always cut straight up and down. There are times when I have to turn around but I do that in the less steep area - 10% slope.
- Bought the tractor used 15 years ago. Since then it has always been fully covered in the barn. Dont know about the first ten years.
- Catastrophic failure at the wrong time is the only concern because of steep slopes - 25 degree and a bit more in one area. Rolling the tractor or having to deal with a flat, with the cutter and FEL attached, on a slope sounds like a bad time.
Are the sidewalls really 3/4" thick? They are 4 ply Firestones.
I also read that tubed tires go flat faster than tubeless?
/ Tires - Replace? #14
If they are tubed & you arent going cross-slppe that decreases the hazard condition a lot. Somewhat new tubes shouldn't fail even if the tires are longer air tight.
/ Tires - Replace? #15
What you gonna do if you get new tires and one goes flat on a slope? Low pressure, slow speed, if a puncture, you'll see wet spot on the tire and have plenty of time to get to safer place.
You might feel safer with foam filled tires.
/ Tires - Replace? #16
My 2 primary tractors don’t have cracks like that - 2016 and 2017. Every other piece of equipment has similar or worse and I don’t think of changing. Flats - yes I get flats. All are from punctures. You are more likely to find a flat some morning due to a slow leak. That’s been my experience with tubed tires - over time the tubes will develop pinholes.
/ Tires - Replace? #17
Are all 4 sidewalls similarly cracked or just some? If just one or both outsides the previous owner may have stored it exposed to the sun on the sides. The tread bays seem to be in good shape.
I have had one rear tire blow out in my days. I knew the tire was on borrowed time as the bead had split but it still was a bit of a pain, but not that bad. The tractor sat in the pasture while I got the new tire for it. Do you have a second tractor with FEL to assist with replacing the tire? If not some farm tire places do field repair/replace.
/ Tires - Replace? #18
I would run them as long as the tread was sufficient for traction. Sun damaged cracks in the rubber dont hurt anything on a tractor tire. The tire cord and inner rubber does all the sealing and pressure holding. My brother in law had an 8N Ford that the cord showed thru with much of the rubber missing, they still held air for weeks at a time but would finally go flat. Just keep the air pressure checked and dont let them get low. Low tire pressure destroys many a tire.
/ Tires - Replace? #19
If you want to emulate a flat and how the tires perform, why not remove the air (valve stem up of course) and ride the tractor around a bit. You may find the there is sufficient sidewall stiffness to support the tractor to at least get it back to where the tire can be conveniently and safely repaired. Don't forget to air back up. :D
