GPM availability on MX5800 for Hydraulic Auger?
   / GPM availability on MX5800 for Hydraulic Auger? #1
Hozzie
Chapel Hill, TN
M7060
While I am pretty good at understanding most things, Hydraulics are still a bit of black box for me. I know that my MX5800 has a total Hydro system gpm of 14.4 (9.5 for pump flow and 4.9 for Power Steering).
I plan to purchase new Danuser hydraulic Auger, either EP6 or EP10. The EP10 says it needs 10-20 GPM to run it, with 12 being recommended minimum. The EP6 has a bit less torque, but only needs 6-15 to run it. I will be running either from my third function valve with 1/2 flat face connectors (if it makes a difference)
I believe there are different types of power steering pumps, some which may use flow at all times and others which may not (could be completely wrong on that). I am trying to figure out if I will have a little extra GPM when using the auger as I will not be moving or really moving my steering in most cases.
The largest auger I will probably ever use is 12" so I am not sure it makes a ton of difference, but I do have a fair amount of rock and clay and figure the extra torque would be nice.
Anyone using an EP10 with a similar sized tractor? I have searched and found similar questions, but am really wondering if my power steering is always pulling from my GPM at full value?
I am not set on either and am not trying to make my tractor do more than it can, just want to buy the right thing the first time.
Thanks!
   / GPM availability on MX5800 for Hydraulic Auger? #2
Following. :popcorntub:
   / GPM availability on MX5800 for Hydraulic Auger? #3
Flow for steering is sacred.... you would not want to be motoring down the road, raise your FEL and loose your steering. No, you have no extra when steering is not being turned.
Are you mounting on FEL? If so, expect, when you use the loader controls, to have the auger stop as your system is "Open Center."
Also remember you have no where near the 3,000 psi their literature uses when advertising the torque figure.
Dave M7040
   / GPM availability on MX5800 for Hydraulic Auger? #4
I have yet to see such hydraulic attachments (typically for SS) being used on a tractor.
I'm not really worried about motoring down the road and running the auger, so I don't see that as an issue. Basically, I will be sitting still, but the open center is valid. Not sure that is a big issue either but definitely something to consider. I am pretty convinced I would need to go with the EP6. It's just for occasional holes for the most part. I just hate always looking backwards for pto attachments.
Seems to be a lot of them out there made specifically for lower GPM usage. Most people I have read that have them seem to like them. I am not doing commercial work. Just want something easier on the neck that a 3pt version. I like the idea of being able to reverse it as well.
   / GPM availability on MX5800 for Hydraulic Auger? #7
The larger unit will develop the advertised torque at the lower flow your tractor will deliver. Auger speed will be the casualty. Generally speaking any hydraulic tool designed for a standard flow skid steer will function acceptably with a flow rate at or near 10 gpm.
Thanks. Got a quote of $2065 for an EP6 with offset qa mount and 9in bit. Think that seems like a good deal I will probably go forward with.
   / GPM availability on MX5800 for Hydraulic Auger? #9
Good to hear that Danuser is making a lower-flow unit, the EP6, for tractors. They are known for pro hi-flow units for skidsteers. They use the hex shaft auger bits.
I have set up 3 PHDs for tractors, 2 were the Worksaver 714H, and I built one from off-the-shelf parts. These use the 2" round shaft augers, shared with PTO PHDs.
The hi-flow PHDs will still work on a tractor, albeit slower, but with more torque, assuming same pressure.
As for your implement pump, the total flow is marketing BS since the PS and HST charge flow is not available for implements.
   / GPM availability on MX5800 for Hydraulic Auger? #10
Sounds pretty good. I expect that a 714/814H from Worksaver would not be a lot less.
2010 Honda Civic Sedan (A50860)
2010 Honda Civic...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
1973 POWER 30ft Pole S/A Towable Trailer (A48081)
1973 POWER 30ft...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
1275 (A50490)
1275 (A50490)
utility bed (A49461)
