Time to convert from small engine to battery tools?
   / Time to convert from small engine to battery tools? #151
Just as a note, I gave the Lynxx chainsaw somewhat of a workout over the weekend, I cut down two fir trees (maybe 40' tall) and limbed them on a charge, might try to buck them up tonight if I can to see how long the battery lasts... I do know the low voltage cutoff kicks in at about 2 bars of battery, which I found out while cutting the wedge out of one of the trees...
For general homeowner use, I give this thing a thumbs up, it would be nice to have variable speed (it's on or off with the trigger) but not a deal breaker... it's quiet as heck and cuts reasonably well similar to about a 30cc saw.
EDIT: Just wanted to add that I just got done bucking the first tree, took just more than a battery, at my best guess you'd get two to two and a half batteries to a tank of fuel in my little top handle Homelite XL chainsaw (either 25 or 30cc depending on year if memory serves). But that said it cuts like a beast with the Oregon chain it comes with... up until it doesn't, wouldn't make a great only saw but not bad with two or three batteries.
   / Time to convert from small engine to battery tools? #152
I saw battery operated Hotel Vac today... seems batteries are gaining broad market share...
The lure of being able to spot clean a hall without extension cord and it was quiet...
   / Time to convert from small engine to battery tools? #153
Curiously, do these use standard chains? I have the Lynx pole saw and while it has an Oregon bar, there's nothing in the manual saying any specs or model # for it.
   / Time to convert from small engine to battery tools? #154
I was skeptical at first-have a Troy Built gas trimmer for 8 years that replaced a cheap trimmer that died on me after 2 years. They are noisy, smelly, vibrate like crazy and are heavy. The gas is hard to manage-refils, freshness and I ended up having the Troy repaired a couple times. It has a quick detach setup and I had the edger and trimmer attachment. I still have it butt... 4 years ago saw they Ryobi 40v trimmer on sale with quick detachment capabilities as well. Read on the box that several quick attachment brand will fit it including the Troy I have,
Today-same 40v Ryobi head is still going strong but now I have-Edger, Pole Saw, Clipper\hedger, Sweaper, blower, trimmer and spare battery. So much easier-original battery still like new and its all easy to carry, no vibration, no hearing protection and no gas to muck with.
Whats awesome is I can go back to the gas trimmer or buy another battery powered with quick det, and still use all my attachments.
   / Time to convert from small engine to battery tools? #156
   / Time to convert from small engine to battery tools? #157
   / Time to convert from small engine to battery tools? #158
Got a polesaw attachment to go with our Kobalt 80 volt system. Cuts good. Dont miss the premix a bit. Would like a chainsaw to go with the system but cant justify the price and already have 6 gas saws. The Lynxx does tempt me when its on sale. I already have their string trimmer and blower.
   / Time to convert from small engine to battery tools? #159
You are KIDDING me!!! (not you personally, Eddie :))
I paid A$155 for a single Makita 6Ah battery a few weeks ago... because it was on sale.
....and that would be part of the reason I watch for specials like that since Makita seems to run buy a tool/charger/battery combo and get two batteries free promos about once every three months or so (in the US at least).
At this point I think I have 8-12 batteries (none under 4Ah) that were all purchased that way with various tools that I was going to get (sooner or later) anyway. Really makes it worth checking their promo site on a semi-regular basis: MAKITA - Cordless and Corded Power Tools, Power Equipment, Pneumatics, Accessories
That's a lot of batteries. How many battery operated tools do you have?
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
500BBL WHEELED...
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
