Just another junk chainsaw
/ Just another junk chainsaw #621
Good news: the symptoms I described yesterday have gone away. I never did diagnose the problem for sure, but I've done a few things to the saw since yesterday:
- my vent line came a day early, so that was installed
- checked torque on the crank case bolts (OK)
- opened up and checked the muffler; some carbon buildup but no oil
- rechecked my carburetor adjustments (if anything I may have gone slightly more rich on the high mix)
Ran the saw for a little while today and no evidence of spitting oil at all. I was going to suggest maybe it was flooded, but think I would have seen oil mix in the muffler in that case. Now I think it must have been something silly like "someone" spilled bar oil under the muffler.
Haven't done any tough work with it yet, but did get to use it today. Had to knock over a small maple, a job for which the tractor was used. Then used the "new" saw to limb and buck it into small enough pieces for the burn pile. Loving it so far... Many thanks for convincing me to bring it back to life.
/ Just another junk chainsaw #622
You guys seem to know a lot about saws. I have a Poulan Pro PP3516AVX and lately it's been suffering from the chain getting loose after about 4 - 5 cuts. For some reason, I can't seem to keep it tight? Looked on youtube without much luck except for suspecting that the chain adjustment mechanism may need replacing. Could that simple screw be my problem? I can't think of whatever else it might be? I have always been leery of the tool-less adjustment; but until lately have had zero issues with it. Could someone throw a thought or two my way?
Appreciate it if so. Thanks Greg
/ Just another junk chainsaw #623
I don't know about that specific model. I do know when I got my 18" model from Poulan, we couldn't keep the chain tight either. Found an offer from Poulan where for one time, they would send you a manual tensioner for free, as they had so many complaints about the tool-less tensioner. I had several friends with the same model. Some of their tensioners worked, and some didn't, like mine. We all took advantage of that free offer and got the manual ones anyway. Maybe it would be worth looking into for your model? :confused3:
/ Just another junk chainsaw #624
Reminds me of my pressure washer where the house connection vibrates loose and sprays water all over if I do not keep tabs on it. :shocked:
If you have the tooless side cover. The little gears get stripped. You can buy them and replace but in time you will do it again.
I advise folks to switch over to the normal clutch cover and tensioner set ups.
Your saws IPL Poulan Gas Chainsaw | PP3516AVX | eReplacementParts.com
/ Just another junk chainsaw #627
Thanks for the tips MossRoad & xyz123, The inner tooth on my tool-less looks as if worn and is probably the root cause.
I was going to go to ereplacement 1st, but wanted to double-check my thoughts prior to just buying parts and hoping they would fix my problem.
I hadn't heard/read about problems with the tool-less; course as long as mine was working fine I had no reason to search for solutions then!
I do have an 18" also (bought @ TSC when it was on sale) I have never yet used. It has the old style screwdriver adjustable cover on it. I will probably just try switching the covers 1st and if that does fix the issue - I'll just buy a new [old style] cover and be back in steady business. Thanks for the suggestions! Greg
/ Just another junk chainsaw #628
I've had the 18" for about 10 years. It's a bit underpowered for full cuts in locust. Works well in cherry an softer wood like sassafras. I'd put that 16" bar on the 42cc saw and it would probably be a pretty darn good saw. The only reason I haven't done that myself is that I had two older 18" saws, several bars, and half a dozen 18" chains.
/ Just another junk chainsaw #629
MossRoad, That was my plan when I bought the 18". I've just been unable - yet - to get the smaller one to completely die! As long as the motor and all still runs good I'm satisfied with how it cuts. I just need to fine-tune getting the chain to stay tight and the info about the tool-less tighteners becoming weak was "very" helpful to me. Once the little one goes dead; the bar and chains (I have several 16") are getting transferred to the bigger guy. This way I'll always have a working saw available at a moments notice [I hope!].
/ Just another junk chainsaw #630
:thumbsup:
I inherited a Craftsman 18" saw from my dad back around 1995. Never used it much. Around 10-11 years ago we started heating with wood and I bought the 42cc 18" poulan factory reconditioned for $100. And about 4 years ago my neighbor gave me his 18" Craftsman. So I'm kinda stuck on those 42cc 18" saws. :laughing: I cut about 6 cords per year for us + an occasional windfall for family and friends with the Poulan. It's been a good saw. Only problems I ever had was the coil cracked. That was darn near $50 after shipping. And the fuel line went mushy inside the tank. That was 20 cents. Both Craftsman saws seem to be a bit more powerful than the Poulan, but they don't have chain brakes, so I only use them once in a while, and maybe if I get the bar pinched on the Poulan. However, the last time I got the bar pinched, I just took the saw off the bar, put on a spare bar and chain, and used that to free the stuck one. It's nice having spare bars and chains in the field. I keep everything in a kitty litter bucket. I think I have 6 chains currently. I sharpen them on a cheap harbor freight sharpener and put them in a ziplock freezer bag with a couple drops of oil. I just swap them out rather than sharpening in the field.
One of those little poulans. Just did a carb rebuild, fuel primer lines, duckbill in cap for a local.
Loaned him a newer strato version to finish his yard limbing he was trying to do. While I work on his saw he bought new many years ago.
/ Just another junk chainsaw #632
@xyz123, what is you way of getting g a saw clean before working on it. I've been using oil eater for the tough stuff, but they never seem to look as immaculate as that one.
On another note, what would you say about this Cman saw? Think it's a Poulan 3400(?). Low compression but P&C looks good. Only paid $60 including the Stihl 025 which will be sold in good condition.IMG_20190604_133518.jpgIMG_20190604_093547.jpg
The 025 as a runner around me brings 100-150. Light 45cc clamshell style.
The 3400 around me as a runner only brings 40-50. But is a 56cc saw but heavy for cc. Good long lasting saws.
I have a partial parts saw here. Green one on right
I just use air , plastic brush. WD40 cleaner too. Plus WD40 spray. Just depends.
/ Just another junk chainsaw #634
My old Shop teacher used a solvent gun and gasoline to clean saws (as he huffed on an ever-present stogie). Made me nervous.
Poulan 2300cva 38cc that original owner gave to a friend of mine.
Came in no start. Had to laugh when I seen the oregon fuel line pinched in 2 places and the dirt in the tank and fuel filter off. Carb kit, new tygon LP1200 fuel line.
Pulled those epa stops for carb tuning. Seems good to go after test cutting.
Will be a back up saw to his 440 310 when needed.
I grabbed one of the projects I bought over the last few years. Since it seems everyone wants a runner not a project to do themselves.
I was told this one was a runner when I bought it PHO. Dang it was, after a quick check over 😲. Took alot of air and brushing to get some of the jammed packed chips everywhere. One of those saws that must have never been cleaned. I even left the old fuel line and impulse line as they looked ok to test with. 1999 Poulan 3450 54cc
I even dug through my parts and found 1 3750 380 60cc OEM used piston and cylinder kit.
IMO I wouldnt change it from the 54cc being it cut so dang good just now in some dry ash with 16" 3/8 buried. With that big dawg maybe 14" cutting.
Pulled them dang epa stops too while tuning. Piston looked like they had been running old mix over the years. Think the batch I am running now is VP racing 40:1 e-free 90. Wondering how long to see if it is cleaning it up.
Some wrong fasteners but I dont give a rip about such things myself.
Check out how packed the pleats were on that air filter. One good thing. The air filter and mating surface did its job, no fines in carb throat. Unlike the new saws that let fines by.
/ Just another junk chainsaw #639
I just acquired this thing, I'd like to know if it's one from the time when Poulon was a decent saw, or if it's a no-never-mind junk saw?
It's a Poulon Pro 260, emissions sticker indicates 2001 model year EPA compliance. The saw is really in near New condition aside from oil and dirt.
Would this be worth resurrecting, it is it trash can fodder?
/ Just another junk chainsaw #640
I'm sure they're not the best saws out there, but I have two of them (both Craftsman branded, same thing just different options like chain break and such) and they run very well. I'm pretty sure one is newer as I think it has the secondary air induction thing above the carb (second throttle plate, kinda goofy). Got the one I've been using for $10 with a case but just the powerhead, got a bar and chain on amazon for $20, don't think I had to get into the carb but might have put a regulator diaphragm in it since most sitting 2 strokes need one... Most people consider them throw away saws since that's the same model that Harbor Freight carries now for $150ish, definitely not professional grade but fine for general homeowner...
Just picked up a Poulan 3400 and a couple of the small Craftsman 2400 saws, couldn't refuse the price, 3400 has the starter rope sticking out but that's usually an easy fix, one of the Craftsman saws is parts since it has zreo compression, got it for parts since I have like 6 of them now...
UNUSED CFG INDUSTRIAL QK16R MINI EXCAVATOR (A62130)
UNUSED CFG...
CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
UNUSED LANDHERO CHAINS & BINDERS (A62131)
UNUSED LANDHERO...
2015 Jeep Wrangler Rubicon Vehicle (MPV), VIN # 1C4BJWFG8FL728783 (A61165)
2015 Jeep Wrangler...
