A few more questions B6100 E
/ A few more questions B6100 E #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
I have factory wheel weights, they are held on with incorrect hardware, makes it difficult to remove as Im assuming the original hardware was a carriage bolt of some type, Ive asked at the dealer, they were not able to find a part number, can anyone offer a suggestion?
A standard carriage bolt will not work cause of clearance issued with the head to rim. I can modify but Id rather just buy the correct hardware. 058.jpg057.jpg056.jpg
Can someone tell me the purpose of the large bolt with the spring in the center as seen in this picture, Id assumed that the center of the rim that comes in contact would be crushed slightly by tightneing the bolt but not in my case, it seems to still be loose on my axle regardless of how much I tighten.
Any why the058.jpg spring?
My air cleaner cap was jury rigged at one point to stay on, one of the clips apparently went missing partially.
I thought I was lucky in that the dealer is still able to supply a new cap with spring clips for 42 dollars which I have ordered just for that one spring clip but Im gonna guess now that I could have bought the clip from an aftermarket source.
Ive asked the dealer to go ahead and order for me so I cant go back, Im just wondering if someone does know of a source for an identical part?
/ A few more questions B6100 E #4
Any why theView attachment 606885 spring?
Study the portion of the Owner's manual dealing with the Hex axle.
Look at the parts illustration.
I think you are missing the pin which goes through one of 3 holes in the axle to set the track width
Part Number 66621-17160 for $6.20 from Messicks
Dave
Thanks I have the pins, one per wheel, it seems this pin ( which is all sloopy ) is what holds the wheel assy onto the axles
/ A few more questions B6100 E #6
A standard carriage bolt will not work cause of clearance issued with the head to rim. I can modify but Id rather just buy the correct hardware. View attachment 606882View attachment 606883View attachment 606884
Suggest you look over the Lonestar Wheel Weight web site.
Wheel Weights - Lonestar Weights
Kubota and other manufacturers were often buying third party products and marketing them as factory stuff.
Dave M7040
/ A few more questions B6100 E #7
Are you actually tightening the bolt? (or is it stripped and just spinning?) the spring acts as sort of a lock washer and is supposed to prevent it from vibrating lose...
/ A few more questions B6100 E #8
I suspect with the pins in place ( not all worn) and the securing bolt tightened, the wheel should be secure.
Investing $13 in two new pins would seem wise
Dave M7040
/ A few more questions B6100 E #9
The chances of finding OEM wheel weight bolts, for a bizarre set up like you have, is about zero. Myself I would buy long enough normal bolts, You could grind large washers to custom fit the rim, then weld it to the bolt head, and insert them from the inside of the rim. That would make it so you just have to use one wrench to remove the weights.
/ A few more questions B6100 E #10
The pins are typically sloppy even when new. The compression bolt with the spring is what tightens the wheel to the axle. Still, that wheel fixing system wasn't the best system for holding the wheel firmly. It isn't in use on many - if any - modern tractors. And never was popular or much used on tractors much larger than yours.
It's an inexpensive way to hold the wheel on and it won't let the wheel slide along the length of the axle if the pins and their keepers were in place. But they were known to be a bit wobbly. It is what it is. There are ways to shim it to work a bit better, but if you put in the pins and tighten that bolt it will get you by.
BTW, you can buy bolts to mount those weights at any hardware store. Yes, the heads will be too big to fit. That's not a problem, simply grind the heads until they fit.
The whole point of having an older tractor like this is that it gives you a chance to exercise your creative mechanical side. I'm betting you are way ahead of me and that you started seeing that with that ridiculously expenseve air filter spring.
Being able to understand when you can legitimately use a simple solution is half the fun of old tractors.... and exercising your ingenuity on a nice little older tractor is a great way to learn mechanics the right way. Pretty soon you will not only be making the simple parts yourself, but some of them are going to be better than the originals.
good luck, rScotty
Dave M7040
I had read that in a previous threead but there wasnt any info on who the third party was, thanks
It is tightening however the wheels are still wobbly
Dave M7040
I understand now that I was correct in what I had noticed and that was that not only are my pins worn but also the wheel itself and most prob the axle. Its not stupid sloppy but Im used to working on more precision tolerances
Consider it done than. Its no problem
good luck, rScotty
Tractors in pretty good shape in my opinion, Im assuming not many around cause of all the attention it gets when I take it out somewhere, Id like to preserve whats left with correct parts if avail, I have lots of other projects that Ive spent alot of time exercising my ingenuity on.
You give some of the best detailed responses. thanks
/ A few more questions B6100 E #12
The system holding on the axle will always be sloppy and break pins. Ordinary bolts work well as a replacement. Duct tape wrapped around the hub will hold the pin pieces in place when they break keeping the wheels in place on the axle. Trying shims helps abit but they will quickly wear out. Kubota has a replacement hub for these type of hold downs.
/ A few more questions B6100 E #13
A lot of those old style hubs broke the safety retaining pins when the compression bolt with the spring either came loose or was lost. Then the hub would wobble on the axle and break the pins. We now know that whole hub wasn't a very good design, endless adjustment and trouble. It just wasn't up to handling the forces a tractor puts on the hub.
A diligent person can make it functional by fitting things carefully, but replacement with an upgraded type of hub to axle fixation would sure be a better answer. Still, if the compression bolt and spring are still there and with good enough threads to tighten down well.... plus pins or bolts as you say - then he could get by for awhile.
I didn't know that they had a replacement hub type. That would be a better long term solution.
rScotty
/ A few more questions B6100 E #14
Fitting carefully works for a very short time in my past expierience.
/ A few more questions B6100 E #15
The little Yanmar I'm rebuilding is about the same size uses about the same hub tightening system. But it was apparently never run loose because it has remained tight for decades now.
You know..... what really interests me is finding out what the upgraded hub fixation looks like. A few posts back someone mentioned that Kubota offered a replacement part that worked better. I'm curious what it looks like.
rScotty
rScotty
Im thinking it may be this Wheel Hub - Rear Kubota B71 B6 B51 B175 B62 B215 B155 B61 Yanmar | eBay
UNUSED KUBOTA BRUSH GUARD (A62130)
UNUSED KUBOTA...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2002 Ford F-550 Dump Truck, VIN # 1FDAF56F32EC86522 (A61165)
2002 Ford F-550...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A61568)
2000 Thomas Built...
UNUSED WOLVERINE TR-26-01C 3PT QUICK HITCH (A62131)
UNUSED WOLVERINE...
(1) 380/85R28 TIRES W/10 LUG RIMS (A62130)
(1) 380/85R28...
