Yanmar 155D running like crap
/ Yanmar 155D running like crap #1
docdox
Yanmar 155D
I have a Yanmar 155D that I use for tilling my garden. Last couple of years it has progressively weakened and now it is very hard to even get it started. I am going to do some checks on it and see if maybe it has a plugged injector but I believe it has a bad cylinder. I have to run it up to 3000 rpm just to move it and when I till it spews black smoke. Meaning it has unburnt fuel which leads me to believe it's a bad cylinder not an injector. It has over 1000 hours on it so probably due for an overhaul anway. One other thing I noticed, when I pulled the air cleaner there was a bunch of diesel in the bottom of the cap. Not supposed to be there........
/ Yanmar 155D running like crap #2
Might try slowly cracking injector line while running to identify bad cylinder. Just remember those lines have high pressure. Good cylinder line cracked will likely kill the engine, bad cylinder might not make much difference.
Thanks for the info winston1
/ Yanmar 155D running like crap #4
Once u narrow it down to which cyl. is giving u problems..
..try swapping the injector to a different hole to see if the problem stays or moves w/ the injector.
Good luck.
/ Yanmar 155D running like crap #5
Agreed to both previous posts. Also do you run use any fuel treatment on a routine basis? If not I would recommend using some in the future.
/ Yanmar 155D running like crap #6
I was just mentioning how Bad my Hyd . fluid and screen was then the Fuel bowl and Filter wasn't much better. Never been big on fuel treatments so after seeing the filter and going through that, My Filter/Bowl gets replaced and cleaned pretty much Yearly. NAPA. has my filter and cheap. Also I never leave much fuel left sitting in the Tank for any period of time. The tractor sits outside under a carport so I have never filled the tank over half way at the most pretty much just a few gallons at a time. And there's opinions on it But I don't use Off road either with a dye. Straight from the pump. So my Tank & fuel bowl stays extremely clean and clear. Tilling which I did also, I never had much Thick BLk smoke. I've bogged it down and had "a lot" of Blk. smoke come out before so you may not have that bad of a problem. And if you go the route as Pumpguy suggests go ahead and run a pressure test and then your know what condition your Cyl. is in also. The RS1400 tiller in the Pic. is as low as it possibly can go on the first turn of Yr.. Notice the exhaust that you can see. No smoke.............
/ Yanmar 155D running like crap #7
Filling your diesel tank halfway is the best way to rust a fuel tank.
/ Yanmar 155D running like crap #8
Really? Don't think that's going to happen!! It's made of Plastic.....:laughing: Even if it was metal I don't think that will happen..... It doesn't have any water in it. Can't say anything about yours though...................
/ Yanmar 155D running like crap #9
Oh. Mine is metal. It is a big problem with old tractors and motorcycles that have not had their tanks full. The condensation is the problem. My friend has an old IH tractor that the fuel line keeps getting clogged with rust from the tank.
/ Yanmar 155D running like crap #10
At just 1000 hours, maybe it's just not broken in yet.
/ Yanmar 155D running like crap #11
Had bikes all my life since I was 12 except for now. First was a good ole XR75. I went down Phys. while on one. It wasn't good!! Here's what I did to prevent condensation and actually back pressure. I seen air bubbles coming out around the Injector return on the tank and new that wasn't a good thing. Came off a old Kawasaki 220 Bayou. Just drilled a hole in my cap and works great. Took care of that potential problem. ;)
/ Yanmar 155D running like crap #13
Condensation is a big problem for any metal fuel tank. I didn't think any of the Yanmars had metal tanks, but if they did I would keep it as full as possible. Use some sort of fuel treatment too, there are plenty of different kinds out there.
/ Yanmar 155D running like crap #14
I had a delivery valve spring on #1 cyl that was missing since the tractor was new. It smoked like **** and one hole wasn't even injecting fuel. Long story short, I'm the 2nd owner and the original owner said it ran like that since he bought it. It started hard and smoked like a freight train. I found the the #1 delivery valve spring was missing. Got two delivery valve springs and valves and it runs like a champ. Also put new injectors in it
Check your spray pattern on both cylinder and see what that tells you after you determine the hole that is "dead"
/ Yanmar 155D running like crap #15
This thread kinda got hijacked.. What happened to Docdox.?? Did u figure out the problem.??
/ Yanmar 155D running like crap #16
Seen this last night and thought the same. My guess why was to me pretty much two things. #1 He found the problem which I think he did. #2 The big one. Having to figure out how check the compression. With most Comp. testers having any Threads that will work. That would have been a guestion on here for sure And if he did find them Low or No!! We would have heard something if it was similar to #2 I'm sure. Sometimes no news is good news. And it all so seems there is a lot of things done and talked on PM. Just sayin..............
/ Yanmar 155D running like crap #17
I wondered that myself. Looking back at the first post I see one thing that we overlooked when Docdox wrote,
" I have to run it up to 3000 rpm just to move it and when I till it spews black smoke. Meaning it has unburnt fuel which leads me to believe it's a bad cylinder not an injector."
Doc, that's not correct. Black smoke doesn't necessarily eliminate the injector. In fact, an injector that is squirting liquid instead of a making a aerosolized spray (as it should) is a common way for injectors to go bad and will certainly make the engine spew black smoke from unburnt fuel.
You can check the injector by removing it - which can be very difficult to do and I'd check some old discussion threads here & maybe buy the special tool.
Anyway, when you get the injector out, you can hook it up, crank the tractor, and see how the injector patterns against a piece of cardboard held a few inches away. Try not to inject your skin with high pressure fuel, big health problems from that, but easy to avoid.
Good luck*
rScotty
* I've noticed that most of the time good luck beats good planning....
/ Yanmar 155D running like crap #18
I know I'm late to this but 1000 hours on that motor is nothing!! With care it should of lasted three to six times that long easy
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63688)
2019 Cadillac...
Saltdogg by Buyers, Slide in Spreader Box (A62679)
Saltdogg by...
2018 CHEVROLET SILVERADO 2500HD (A65643)
2018 CHEVROLET...
New/Unused AGT Industrial SDA-140T Track Loader (A65579)
New/Unused AGT...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
