/ Harbor Freight Tools that don't suck #11,141
Was that the one for April that expired already? I see the predator engine pump coupon for 30.00 off of any gas engine pump but not for just a gas engine. Sorry to be dense. :)
/ Harbor Freight Tools that don't suck #11,142
Thanks, I saw that one too I just don't know if that's overkill for me. I need to do something so I don't ruin my new air grinders and for the occasional plasma cutter usage. I've been looking on Amazon also. Maybe I should add 2, one bigger one at the compressor and one small one as the hose exits my basement wall.
That is exactly what I have done plus the desiccant dryer.
/ Harbor Freight Tools that don't suck #11,143
Nope ,the last one that just came a few days ago,says June 2019 issue. It had a 25% coupon pasted on cover good for Memorial Day Only.
/ Harbor Freight Tools that don't suck #11,144
Yep... this is the one I just received too.
/ Harbor Freight Tools that don't suck #11,145
Same issue I just got also - but the 25% coupon has all the usual restrictions, INCLUDING no Predator stuff - also, the link I posted earlier
Harbor Freight Tools Coupon Database - Coupon Search for: engine
has the 6.5 horse horizontal engine, the 13 horse horizontal I bought, plus both the horizontal and vertical 22 horse engines - good til 5/31 on the larger engines and 6/30 on the 6.5 horse.
You can just print out from the hfqpdb link, unless you prefer to only save 10% :D ...Steve
/ Harbor Freight Tools that don't suck #11,146
For some reason I haven't received the June catalog yet. I was wanting the 8hp engine (301) for this project. The 13 hp is a great deal but too much engine and too much weight for the BCS 720 I need to repower. So 10% off of the 229.00 price would be great. I messed around and let the April coupon for 10% off a Predator engine expire.
/ Harbor Freight Tools that don't suck #11,147
Can anyone tell me if the 8 hp Predator is still 229 in the June flyer?
/ Harbor Freight Tools that don't suck #11,151
/ Harbor Freight Tools that don't suck #11,152
Anybody with recent experience with the HF pallet jack? I found a TBN thread from 2011 that gave positive reviews but wonder if the current model is also good.
I just bought 1 a couple weeks ago. I have most of my tractor implements on pallets. I store them on racks when not using them and now I can move them around on the floor with the pallet jack. I couldn't be happier with it so far. I could have chased a few auctions around and bought a better quality one (that was 50% or more worn out) for $75 to $100. That would take time and I wanted it now. I can't imagine I will wear it out with my use. I had a 20% off coupon so was a little over $200.
/ Harbor Freight Tools that don't suck #11,153
The son used the Lyxx chain saw today to get down a young tree blocking the security light for a few years one limb at a time. Now I can to better get around at night. It was still showing 4 bars after some usage. I realized how little the saw ran on tasks like that. It is a fast turning chainsaw too. He called it a keeper.
/ Harbor Freight Tools that don't suck #11,154
Many thanks, looks like a good bet.
/ Harbor Freight Tools that don't suck #11,155
I would never buy a HF pallet jack just because I suspect what poor quality seals they probably use. A non functioning pallet truck is quite annoying. If you have not experienced that, you might not understand my apprehension.
/ Harbor Freight Tools that don't suck #11,157
HF has a recall on their Greenwood Propane Torches both with and without igniters.
https://images.harborfreight.com/hftweb/recalls/Propane-Torch-Recall-61589_61595.pdf
I bought one of these from HF about 15 years ago and was getting concerned about how brittle the hose seemed. So, I bought a new one, last year, and seems the new one is in the recall.
Thanks, Rick. I have the self-igniting one I bought about 5 years ago. Need to check it when I get home. Haven't had any trouble with it so far.
/ Harbor Freight Tools that don't suck #11,159
First 'live' use of the 2K Inverter Generator since I've had it. Utility power's been out for about 2 hours now.
/ Harbor Freight Tools that don't suck #11,160
No sooner posted that than it died on me. Went out to check, restarted and it ran fine for a few minutes then died again. Then I noticed the vent lever on the gas cap that has to be open to prevent the vacuum from making it think it was out of gas. Opened that, restarted, ran a few minutes, then utility power kicked back in.
Oh well.
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2020 Mack Anthem...
FLAT BED (A60736)
FLAT BED (A60736)
Kubota M125X (A60462)
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
