JD 4410 #rd Remote Lock Valve
/ JD 4410 #rd Remote Lock Valve #1
mike48130
Plymouth, MI
JD 4410, 4210 Ford 1700, 550, Bobcat 843
I just bought a T6 Harley rake with the hydraulic angle. The cylinder keeps slipping since the T6 does not have a lock valve on it to lock the cylinder and keep it from moving.
I found one on Surplus Center that will work for $120 that I can put on the T6 with some new hoses and such, but I was wondering if they made anything for the tractor side for this? I did not see anything in the parts catalog or kit list, but would be nice to do it once on the tractor. I am looking at adding the hydraulic angle cylinder to my rear snow plow as well, so I would have to buy 2 of these.
Just curious if I am missing something.
Thanks,
I took a closer look at the valve parts and technical manual. The schematics show the lock valve on the 2 loader circuits, but not the 3rd. The manual shows the valve has caps for all 3 spools, so I am wondering if I can add it to the 3rd SCV? I don't see anywhere where it was sold as an option or as kit.
The part number for the check valve in the parts manual is AM100201.
/ JD 4410 #rd Remote Lock Valve #3
Mike
Post a screen shot of that lock valve.. I'd like to know more about what you are seeing and calling a lock valve.. tks.
Mike
JD calls it the Load Check Valve. The external ones are usually called Lock Valves.
Lock Valve 1/2" NPT 25 GPM 3 PSI | Check & Lock Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
/ JD 4410 #rd Remote Lock Valve #5
Ok, check valve makes sense to me.. tks
Now, the cylinder that is "slipping", is that on the 3rd SCV of the Deere 4410 ?
Those Harley rakes are nice.. hope you enjoy yours and the Surplus Center lock valve isn't redundant to the Deere check valve that may not be functional.
Yes connected to the 3rd SCV.
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A61574)
2005 Freightliner...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2005 JOHN DEERE 700H LGP CRAWLER DOZER (A64279)
2005 JOHN DEERE...
2017 Ford F-550 4x4 Venturo ET25KX 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
John Deere 50 (A60462)
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
